Salta al contenuto principale
How to Position a Vernier Caliper
Cosa ti serve
  1. How to Position a Vernier Caliper, Good Practice: passo 1, immagine 1 di 2 How to Position a Vernier Caliper, Good Practice: passo 1, immagine 2 di 2
    • Use the metal wheel contacting the measured surfaces.
    • This will allow for a more repeatable measurement.
    • Extend the calibration life of the device. Preventing damage to the measuring surfaces or measured part.
    • Make use of the locking mechanism.
    • Occasionally the device has to be positioned in a way that cannot be read.
    • Always prioritize comfort. If there is a change the jaws can move when attempting to read. Lock the device. Move it to you.
    • Ensure the part is secure, use flat surfaces, try to use the vernier comfortably with both hands.
  2. How to Position a Vernier Caliper, External Feature: passo 2, immagine 1 di 3 How to Position a Vernier Caliper, External Feature: passo 2, immagine 2 di 3 How to Position a Vernier Caliper, External Feature: passo 2, immagine 3 di 3
    • External features are measured as shown.
    • These sections of the jaws have a knife edge,
    • Used to measure smaller features with low clearances.
    • These sections have a flat edge.
    • Used to measure larger features with perpendicular surfaces.
  3. How to Position a Vernier Caliper, Internal Feature: passo 3, immagine 1 di 1
    • Internal features are measured as shown.
  4. How to Position a Vernier Caliper, Height: passo 4, immagine 1 di 3 How to Position a Vernier Caliper, Height: passo 4, immagine 2 di 3 How to Position a Vernier Caliper, Height: passo 4, immagine 3 di 3
    • Heights of steps are measured as shown.
    • Butt the head of the caliper against one surface.
    • Butt the head of the slider against the other surface.
  5. How to Position a Vernier Caliper, Depth: passo 5, immagine 1 di 2 How to Position a Vernier Caliper, Depth: passo 5, immagine 2 di 2
    • Depth of holes are measured as shown.
    • Position the blade to the center of the hole.
    • Hold the end of the caliper flush the surface of the hole.
    • Extend the slider until the blade bottoms out the hole.
Conclusione
Happy Measuring
Altre 6 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,982
