Salta al contenuto principale
How to Pick Up a Dropped Stitch in Knitting
Cosa ti serve
  1. How to Pick Up a Dropped Stitch in Knitting, How to Pick Up a Dropped Stitch in Knitting: passo 1, immagine 1 di 1
    • Locate the dropped stitch.
    • A dropped stitch is a loop of unsecured yarn, which means that no yarn is going through the loop.
  2. How to Pick Up a Dropped Stitch in Knitting: passo 2, immagine 1 di 2 How to Pick Up a Dropped Stitch in Knitting: passo 2, immagine 2 di 2
    • Insert the left needle through the loop of the dropped stitch.
    • You may use the right needle to grab the dropped stitch, but the dropped stitch must end on the left needle.
  3. How to Pick Up a Dropped Stitch in Knitting: passo 3, immagine 1 di 1
    • Locate the bar of yarn behind the dropped stitch.
    • Depending on how many rows the stitch has unraveled, there may be multiple bars of yarn. If the stitch has unraveled more than one row, locate the bottom bar.
  4. How to Pick Up a Dropped Stitch in Knitting: passo 4, immagine 1 di 2 How to Pick Up a Dropped Stitch in Knitting: passo 4, immagine 2 di 2
    • Insert the right needle beneath the bottom bar of yarn and lift it onto the left needle.
  5. How to Pick Up a Dropped Stitch in Knitting: passo 5, immagine 1 di 2 How to Pick Up a Dropped Stitch in Knitting: passo 5, immagine 2 di 2
    • Use the tight needle to slip the dropped stitch over the bar of yarn.
  6. How to Pick Up a Dropped Stitch in Knitting: passo 6, immagine 1 di 3 How to Pick Up a Dropped Stitch in Knitting: passo 6, immagine 2 di 3 How to Pick Up a Dropped Stitch in Knitting: passo 6, immagine 3 di 3
    • Repeat steps 3-5 for each row that the dropped stitch has unraveled.
  7. How to Pick Up a Dropped Stitch in Knitting: passo 7, immagine 1 di 1
    • Once the dropped stitch has been picked up all the way to the current row, proceed in pattern.
Conclusione
Your knitting project should now be fixed, and you can proceed with your work.
Jillian Garcia
Membro da: 09/28/22
175 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 426
