Salta al contenuto principale
How to Patch a Tear in Vinyl Furniture
Cosa ti serve
  1. How to Patch a Tear in Vinyl Furniture, How to Patch a Tear in Vinyl Furniture: passo 1, immagine 1 di 1
    • Clean the damaged area with rubbing alcohol, using a rag, paper towel, or Q-tip.
  2. How to Patch a Tear in Vinyl Furniture: passo 2, immagine 1 di 1
    • Cut the backing fabric large enough to cover the tear, approximately half an inch larger around the tear.
  3. How to Patch a Tear in Vinyl Furniture: passo 3, immagine 1 di 2 How to Patch a Tear in Vinyl Furniture: passo 3, immagine 2 di 2
    • Use the spatula tool to insert the backing fabric underneath the tear.
  4. How to Patch a Tear in Vinyl Furniture: passo 4, immagine 1 di 2 How to Patch a Tear in Vinyl Furniture: passo 4, immagine 2 di 2
    • Use the spatula to apply the adhesive to the damaged area.
    • Choose a color that matches your furniture. You may need to mix colors to acheive the correct shade.
  5. How to Patch a Tear in Vinyl Furniture: passo 5, immagine 1 di 1
    • Let the adhesive dry for approximately four hours.
    • You may use a hair dryer to speed up the drying process.
  6. How to Patch a Tear in Vinyl Furniture: passo 6, immagine 1 di 2 How to Patch a Tear in Vinyl Furniture: passo 6, immagine 2 di 2
    • Use a Q-tip dipped in rubbing alcohol to buff and blend the area.
    • Apply light pressure to even out the edges.
Conclusione
Once the adhesive is dry, the furniture is ready for use!
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 37
Ultimi 30 Giorni: 229
Tutti i Tempi: 25,247
