Salta al contenuto principale
How to Patch a Hole in Jeans with Wool
Cosa ti serve
  1. How to Patch a Hole in Jeans with Wool, Patching a hole in Jean: passo 1, immagine 1 di 3 How to Patch a Hole in Jeans with Wool, Patching a hole in Jean: passo 1, immagine 2 di 3 How to Patch a Hole in Jeans with Wool, Patching a hole in Jean: passo 1, immagine 3 di 3
    • Cut a piece of felt large enough to cover the hole
  2. How to Patch a Hole in Jeans with Wool: passo 2, immagine 1 di 2 How to Patch a Hole in Jeans with Wool: passo 2, immagine 2 di 2
    • Insert thread through the needle hole.
  3. How to Patch a Hole in Jeans with Wool: passo 3, immagine 1 di 3 How to Patch a Hole in Jeans with Wool: passo 3, immagine 2 di 3 How to Patch a Hole in Jeans with Wool: passo 3, immagine 3 di 3
    • Make a loop at the end of the thread.
    • Pull the end of the thread through the loop creating a knot.
  4. How to Patch a Hole in Jeans with Wool: passo 4, immagine 1 di 3 How to Patch a Hole in Jeans with Wool: passo 4, immagine 2 di 3 How to Patch a Hole in Jeans with Wool: passo 4, immagine 3 di 3
    • Grab the end of the jean with your hand.
    • Pull the jean towards you, making it inside out.
    • Place the felt on the hole.
  5. How to Patch a Hole in Jeans with Wool: passo 5, immagine 1 di 3 How to Patch a Hole in Jeans with Wool: passo 5, immagine 2 di 3 How to Patch a Hole in Jeans with Wool: passo 5, immagine 3 di 3
    • Pinch together the jean and the felt.
    • Insert the needle horizontally into the jean and edge of the felt.
    • Pull the needle through till the knot touches the felt.
    • Repeat the above steps until the border of the felt is stitched.
    • Make a knot at the end.
    • Cut off excess thread.
  6. How to Patch a Hole in Jeans with Wool: passo 6, immagine 1 di 3 How to Patch a Hole in Jeans with Wool: passo 6, immagine 2 di 3 How to Patch a Hole in Jeans with Wool: passo 6, immagine 3 di 3
    • Grasp the end of the jeans and pull them towards you to turn them right side out.
    • Insert the foam board into the pants and position it underneath the hole.
  7. How to Patch a Hole in Jeans with Wool: passo 7, immagine 1 di 3 How to Patch a Hole in Jeans with Wool: passo 7, immagine 2 di 3 How to Patch a Hole in Jeans with Wool: passo 7, immagine 3 di 3
    • Grab more than enough wool to cover the size of your hole, ensuring it is at least an inch thick.
    • Rub the wool between hands to make a ball.
    • Place the wool on top of the hole.
  8. How to Patch a Hole in Jeans with Wool: passo 8, immagine 1 di 3 How to Patch a Hole in Jeans with Wool: passo 8, immagine 2 di 3 How to Patch a Hole in Jeans with Wool: passo 8, immagine 3 di 3
    • Stab the wool through the jean and onto the foam board.
    • Repeat until the wool is hardened.
  9. How to Patch a Hole in Jeans with Wool: passo 9, immagine 1 di 3 How to Patch a Hole in Jeans with Wool: passo 9, immagine 2 di 3 How to Patch a Hole in Jeans with Wool: passo 9, immagine 3 di 3
    • Rub some soap onto the wool to tangle the fibers.
    • Place the jeans into the laundry machine.
    • Wash on cold and air dry.
    • Wear your cute mended pants!
Linea Traguardo
LiTong Liu
Membro da: 04/25/24
169 Reputazione
1 Guida realizzata
UC Davis, Team 1-2, Whithaus Spring 2024 Membro di UC Davis, Team 1-2, Whithaus Spring 2024
UCD-WHITHAUS-S24S1G2
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 77
Tutti i Tempi: 208
