Salta al contenuto principale
How to Patch Large Holes in a Quilt
Cosa ti serve
  1. How to Patch Large Holes in a Quilt, How to Patch Large Holes in a Quilt: passo 1, immagine 1 di 3 How to Patch Large Holes in a Quilt, How to Patch Large Holes in a Quilt: passo 1, immagine 2 di 3 How to Patch Large Holes in a Quilt, How to Patch Large Holes in a Quilt: passo 1, immagine 3 di 3
    • Carefully cut away damaged, torn, or frayed fabric.
  2. How to Patch Large Holes in a Quilt: passo 2, immagine 1 di 1
    • Measure the size of the hole. You will need to add a 1/2 inch to the width and length for seam allowance.
    • For example, if your hole is 5 inches by 5 inches your new fabric will measure 5.5 inches by 5.5 inches.
  3. How to Patch Large Holes in a Quilt: passo 3, immagine 1 di 2 How to Patch Large Holes in a Quilt: passo 3, immagine 2 di 2
    • Measure and cut out your batting. The batting will be the exact size of the hole.
  4. How to Patch Large Holes in a Quilt: passo 4, immagine 1 di 2 How to Patch Large Holes in a Quilt: passo 4, immagine 2 di 2
    • Measure and cut out your new fabric.
    • Remember to add your 1/2 inch for seam allowance.
  5. How to Patch Large Holes in a Quilt: passo 5, immagine 1 di 1
    • Fold the edges of the fabric over 1/4 inch. Press with an iron.
    • Work your way around until all sides of the fabric are pressed 1/4 inch.
  6. How to Patch Large Holes in a Quilt: passo 6, immagine 1 di 1
    • With the wrong side of the fabric facing up, lay the batting on top of the fabric. Make sure the edge of the batting and fabric align.
  7. How to Patch Large Holes in a Quilt: passo 7, immagine 1 di 1
    • Place the batting and fabric over the hole. The batting will be under the new fabric.
  8. How to Patch Large Holes in a Quilt: passo 8, immagine 1 di 2 How to Patch Large Holes in a Quilt: passo 8, immagine 2 di 2
    • Pin the fabric and batting into place on the quilt.
  9. How to Patch Large Holes in a Quilt: passo 9, immagine 1 di 2 How to Patch Large Holes in a Quilt: passo 9, immagine 2 di 2
    • Using a 1/4 seam, attach the patch by sewing along the edges.
  10. How to Patch Large Holes in a Quilt: passo 10, immagine 1 di 2 How to Patch Large Holes in a Quilt: passo 10, immagine 2 di 2
    • There are two options for quilting the fabric: freehand or decorative stitch. The goal is to top stitch the fabric in an even pattern so that it is extra secure. This adds to the longevity of the quilt.
    • Option 1: Freehand (pictured)- using chalk or a fabric pen, mark your fabric in an even pattern like cross-hatch or a grid. The second picture shows the cross-hatch pattern highlighted in red.
    • Next, sew along your marked pattern.
    • Option 2: Decorative stitch- many newer sewing machines can apply a decorative stitch. You may still need to mark a general pattern to follow.
  11. How to Patch Large Holes in a Quilt: passo 11, immagine 1 di 1
    • Following your pattern, top stitch over the patch.
  12. How to Patch Large Holes in a Quilt: passo 12, immagine 1 di 1
    • Trim excess threads.
  13. How to Patch Large Holes in a Quilt: passo 13, immagine 1 di 1
    • Admire your handiwork!
Conclusione
Congratulations! You have successfully patched a quilt! Your work will ensure your quilt will be used for decades to come.
Mariah A.
Membro da: 09/20/24
217 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 47
Tutti i Tempi: 235
