Salta al contenuto principale
How to Open Logitech Harmony 1100
Cosa ti serve
  1. How to Open Logitech Harmony 1100, How to Open Logitech Harmony 1100: passo 1, immagine 1 di 2 How to Open Logitech Harmony 1100, How to Open Logitech Harmony 1100: passo 1, immagine 2 di 2
    • Remove the battery cover by pushing down on the circled areas and pushing outward.
    • Remove the battery by lifting up the battery on the corner exposed by the indent in the case
  2. How to Open Logitech Harmony 1100: passo 2, immagine 1 di 1
    • Use a J0 screwdriver head
    • Remove the 3 screws from battery compartment
  3. How to Open Logitech Harmony 1100: passo 3, immagine 1 di 2 How to Open Logitech Harmony 1100: passo 3, immagine 2 di 2
    • Open the connector port on the side.
    • Remove screw with a PH00 screwdriver head.
  4. How to Open Logitech Harmony 1100: passo 4, immagine 1 di 3 How to Open Logitech Harmony 1100: passo 4, immagine 2 di 3 How to Open Logitech Harmony 1100: passo 4, immagine 3 di 3
    • Use plastic opening tool to pry at the open slits on the side.
    • One or two silver foam cubes may pop out of the device. These belong in the slots shown in the third picture. They do not need to go back until reassembly.
    • The plastic connector door will fall off. It will need to be put back upon reassembly.
Conclusione
Ohio State, Team 1-5, Garvin Spring 2016 Membro di Ohio State, Team 1-5, Garvin Spring 2016
OSU-GARVIN-S16S1G5
3 Membri
3 Guide realizzate
1Commento della guida
Will changing the battery reset the settings within the remote?
wiboman AT gmail DOT com
Wibo Lammerts - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,558
