Salta al contenuto principale
How to Mend a Snapped Elastic
Cosa ti serve
  1. How to Mend a Snapped Elastic, Snapped Elastic: passo 1, immagine 1 di 1
    • Secure one piece of the elastic.
    • A piece of tape or a heavy object, like a book, are both great options.
  2. How to Mend a Snapped Elastic: passo 2, immagine 1 di 1
    • Thread the needle with your desired thread.
    • Tie the thread off at both ends.
  3. How to Mend a Snapped Elastic: passo 3, immagine 1 di 2 How to Mend a Snapped Elastic: passo 3, immagine 2 di 2
    • Poke the needle through the back side of your elastic.
    • Thread all of the thread through.
    • Be cautious of where the needle is at all times!
  4. How to Mend a Snapped Elastic: passo 4, immagine 1 di 2 How to Mend a Snapped Elastic: passo 4, immagine 2 di 2
    • Continue to thread the needle through, securing the elastic together.
    • Keep track of which side you want to be the back and which side will be the front.
  5. How to Mend a Snapped Elastic: passo 5, immagine 1 di 2 How to Mend a Snapped Elastic: passo 5, immagine 2 di 2
    • Experiment with different designs to secure the pieces together.
    • Use same-colored thread and simple lines to achieve a concealed repair, or use a colorful thread and a fun shape for a statement.
  6. How to Mend a Snapped Elastic: passo 6, immagine 1 di 1
    • Once the elastic is secure, finish the thread by snipping off the excess and tying the end into a knot.
  7. How to Mend a Snapped Elastic: passo 7, immagine 1 di 1
    • Secure the end of the thread with glue if desired.
    • If you choose to complete this step, check the glue's cure time. Wait until this cure time is over to proceed to the next step.
  8. How to Mend a Snapped Elastic: passo 8, immagine 1 di 1
    • Test the elastic to make sure it is secure.
Conclusione
Show off your newly repaired elastic with pride!
Claire Jones
Membro da: 09/19/24
157 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 37
Tutti i Tempi: 349
