Have ever found yourself with a piece of clothing that has a hole in it that you would like covered, but don't want to use a patch? Mending that item with darning loom may be the right option for you. The thread used in this guide is two different colors from the color of the fabric in order to distinguish them easier when you are learning. In your project, you can use the same color thread as the fabric in order to blend it into your garment. This guide will take you through, step by step, how to use a darning loom to mend a hole in your an item of clothing or other fabric.
Thread the needle with the second embroidery floss or thread. Ensure the length of this thread is long enough to cross the width of the hole at least 15-20 times.
If the hole is larger in length, you may need to cut the thread longer.
Make a stitch just to the left of the first stitch you made with the first thread used.
Using the the metal parts of the hooks at the top of the loom, move all hooks to the left side before beginning to move the needle through the threads to the left.
Using the the metal parts of the hooks at the top of the loom, move all hooks to the right side before beginning to move the needle through the threads to the right.
