Salta al contenuto principale
How to Manually Configure Timer Relay Box
Cosa ti serve
  1. How to Manually Configure Timer Relay Box, Access Config files: passo 1, immagine 1 di 1
    • Connect the microcontroller to any computer.
    • The device will pop up as a removable disk. Open the drive.
    • Open the config folder
  2. How to Manually Configure Timer Relay Box, Reconfigure Delay Settings: passo 2, immagine 1 di 3 How to Manually Configure Timer Relay Box, Reconfigure Delay Settings: passo 2, immagine 2 di 3 How to Manually Configure Timer Relay Box, Reconfigure Delay Settings: passo 2, immagine 3 di 3
    • Open trigger.py in any plain text editor.
    • Edit the value (seconds) to change the delay before the device is powered on.
    • Open power.py in any plain text editor.
    • Change the value (seconds) to change the delay the device is powered on for.
Conclusione
Reassemble the device.
James Schreiber
Membro da: 02/10/22
230 Reputazione
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 33
Tutti i Tempi: 161
