Salta al contenuto principale
How to Make a Hockey Stick Longer
Cosa ti serve
  1. How to Make a Hockey Stick Longer, How to Make a Hockey Stick Longer: passo 1, immagine 1 di 2 How to Make a Hockey Stick Longer, How to Make a Hockey Stick Longer: passo 1, immagine 2 di 2
    • Procure an extender that will fit your stick.
    • Your stick should say if it is a junior or senior stick; get the corresponding extender.
  2. How to Make a Hockey Stick Longer: passo 2, immagine 1 di 1
    • Remove the tape on the end of the stick.
  3. How to Make a Hockey Stick Longer: passo 3, immagine 1 di 1
    • Remove the plug/stopper from the end of the stick using a spudger.
  4. How to Make a Hockey Stick Longer: passo 4, immagine 1 di 2 How to Make a Hockey Stick Longer: passo 4, immagine 2 di 2
    • Heat the glue on the extender with a hair dryer for approximately four minutes.
    • The glue should look wet and sticky.
  5. How to Make a Hockey Stick Longer: passo 5, immagine 1 di 1
    • Heat the end of the stick up where you will insert the extender for about five minutes.
  6. How to Make a Hockey Stick Longer: passo 6, immagine 1 di 3 How to Make a Hockey Stick Longer: passo 6, immagine 2 di 3 How to Make a Hockey Stick Longer: passo 6, immagine 3 di 3
    • Insert the extender into the butt of the stick.
    • You can flip the stick and use the ground to help get the extender in all the way since it is a snug fit.
    • You can use the hair dryer as needed to heat the glue and the stick up more if you are having a hard time getting the extender in.
  7. How to Make a Hockey Stick Longer: passo 7, immagine 1 di 1
    • Wipe the excess glue where the stick and extender join with a rag or napkin.
    • Allow the glue to dry for about 10 minutes.
    • You can also go onto the next step if the stick is cooled down to normal temperature.
  8. How to Make a Hockey Stick Longer: passo 8, immagine 1 di 2 How to Make a Hockey Stick Longer: passo 8, immagine 2 di 2
    • Tape the top of the stick or install grip tape (optional).
Linea Traguardo
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 195
