Salta al contenuto principale
How to Lengthen a Pair of Shorts
Cosa ti serve
  1. How to Lengthen a Pair of Shorts, How to Lengthen a Pair of Shorts: passo 1, immagine 1 di 3 How to Lengthen a Pair of Shorts, How to Lengthen a Pair of Shorts: passo 1, immagine 2 di 3 How to Lengthen a Pair of Shorts, How to Lengthen a Pair of Shorts: passo 1, immagine 3 di 3
    • Pick a pair of shorts you would like to lengthen.
    Chiedi a FixBot
    Aggiungi Commento
  2. How to Lengthen a Pair of Shorts: passo 2, immagine 1 di 3 How to Lengthen a Pair of Shorts: passo 2, immagine 2 di 3 How to Lengthen a Pair of Shorts: passo 2, immagine 3 di 3
    • Cut up some fabric using a pair of scissors from any pair of pants you no longer need.
    • Feel free to measure it to the desired length you want.
    • Be careful when cutting with the scissors.
    Chiedi a FixBot
    Aggiungi Commento
  3. How to Lengthen a Pair of Shorts: passo 3, immagine 1 di 3 How to Lengthen a Pair of Shorts: passo 3, immagine 2 di 3 How to Lengthen a Pair of Shorts: passo 3, immagine 3 di 3
    • Cut the folded part at the bottom and unfold the shorts.
    Chiedi a FixBot
    Aggiungi Commento
  4. How to Lengthen a Pair of Shorts: passo 4, immagine 1 di 2 How to Lengthen a Pair of Shorts: passo 4, immagine 2 di 2
    • Unfold the bottom and iron it out to make the hem straighter and cleaner.
    Chiedi a FixBot
    Aggiungi Commento
  5. How to Lengthen a Pair of Shorts: passo 5, immagine 1 di 3 How to Lengthen a Pair of Shorts: passo 5, immagine 2 di 3 How to Lengthen a Pair of Shorts: passo 5, immagine 3 di 3
    • Turn the pants inside out.
    • Line the fabric strips to the bottom of the shorts. The right sides should be together.
    • Align the raw edges and begin sewing either by hand or machine.
    Chiedi a FixBot
    Aggiungi Commento
  6. How to Lengthen a Pair of Shorts: passo 6, immagine 1 di 3 How to Lengthen a Pair of Shorts: passo 6, immagine 2 di 3 How to Lengthen a Pair of Shorts: passo 6, immagine 3 di 3
    • Sew the fabric strips to the shorts using a straight stitch along the lined edge.
    • Finish sewing and turn the shorts back to the front.
    Chiedi a FixBot
    Aggiungi Commento
  7. How to Lengthen a Pair of Shorts: passo 7, immagine 1 di 3 How to Lengthen a Pair of Shorts: passo 7, immagine 2 di 3 How to Lengthen a Pair of Shorts: passo 7, immagine 3 di 3
    • Fold the fabric down and press the seam.
    • Sew a second straight stitch along the folded edge for a clean finish.
    • Repeat the process for both legs of the shorts to make sure they are even.
    Chiedi a FixBot
    Aggiungi Commento
Linea Traguardo
Precious Uwadia
Membro da: 06/27/24
145 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 17
Ultimi 30 giorni: 91
Tutti i Tempi: 751
