Salta al contenuto principale
How to Lengthen a Necktie
Cosa ti serve
  1. How to Lengthen a Necktie, How to Lengthen a Necktie: passo 1, immagine 1 di 2 How to Lengthen a Necktie, How to Lengthen a Necktie: passo 1, immagine 2 di 2
    • Measure for the length to add to the tie by measuring from the end of the tie to the belt loop.
    • Add five inches to that length. This is how long your fabric insert should be.
    • In this photo, the tie is 8 inches too short. Add the 8 inches to the 5 inches needed for seams. I need 13 extra inches for the fabric insert.
  2. How to Lengthen a Necktie: passo 2, immagine 1 di 2 How to Lengthen a Necktie: passo 2, immagine 2 di 2
    • In this step, measure to find out where to add the extra fabric to the tie, so that the insert will be hidden beneath the collar.
    • Measure from the clavicle to the belt loop.
    • Add two inches.
    • In this photo, the person is 22" from clavicle to belt loop, so I will insert the fabric at 24" from the wide tip of the tie.
  3. How to Lengthen a Necktie: passo 3, immagine 1 di 1
    • From the widest end of the tie, measure the desired length, in this case, 24 inches.
    • Mark the spot with a fabric marker. This is where you will cut the tie in Step 7.
  4. How to Lengthen a Necktie: passo 4, immagine 1 di 1
    • Rip the seams along the back of the tie using a seam ripper.
  5. How to Lengthen a Necktie: passo 5, immagine 1 di 2 How to Lengthen a Necktie: passo 5, immagine 2 di 2
    • Remove the inner white section of the tie by folding outward and placing on the widest part of tie.
  6. How to Lengthen a Necktie: passo 6, immagine 1 di 1
    • Unfold the tie.
    • Measure the diagonal width of the tie.
    • You will cut the piece of fabric insert to this width.
  7. How to Lengthen a Necktie: passo 7, immagine 1 di 1
    • Using a rotary cutter on a cutting board, cut the tie diagonally along the section you marked with the fabric marker in Step 3.
  8. How to Lengthen a Necktie: passo 8, immagine 1 di 2 How to Lengthen a Necktie: passo 8, immagine 2 di 2
    • Cut a piece of fabric to match the length and width desired.
    • In this case, I am adding a piece of fabric 13 inches long and 6 inches wide, but the measurements will be different for each person depending on the width of the tie and the length being added.
  9. How to Lengthen a Necktie: passo 9, immagine 1 di 2 How to Lengthen a Necktie: passo 9, immagine 2 di 2
    • Pin the extra fabric along the cut portion of the tie so that added fabric forms a "V."
  10. How to Lengthen a Necktie: passo 10, immagine 1 di 1
    • Sew the insert in place.
  11. How to Lengthen a Necktie: passo 11, immagine 1 di 1
    • Pin second portion of original tie in place so that the original tie and the added fabric forms a "V".
  12. How to Lengthen a Necktie: passo 12, immagine 1 di 1
  13. How to Lengthen a Necktie: passo 13, immagine 1 di 1
    • After sewing both ends in place, the tie should look like this.
    • Unfold the inner tie lay it back inside the tie.
  14. How to Lengthen a Necktie: passo 14, immagine 1 di 2 How to Lengthen a Necktie: passo 14, immagine 2 di 2
    • Iron the inserted fabric so that it follows the fold pattern of the original tie.
  15. How to Lengthen a Necktie: passo 15, immagine 1 di 1
    • Hand sew down the entire length of the back of the tie.
  16. How to Lengthen a Necktie: passo 16, immagine 1 di 2 How to Lengthen a Necktie: passo 16, immagine 2 di 2
    • The tie is now the desired length and will reach the belt when worn.
Conclusione
This repair is a great knowledge to have for tall people who wear ties on a regular basis.
Mel Anderson
Membro da: 06/13/21
253 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 24
Tutti i Tempi: 1,956
