Salta al contenuto principale
How to Lengthen Dress Pants
Cosa ti serve
  1. How to Lengthen Dress Pants, How to Lengthen Dress Pants: passo 1, immagine 1 di 1
    • Start by carefully ripping the seam of the pants with a seam ripper. Make sure not to leave holes in the fabric or it will show in the finished product.
  2. How to Lengthen Dress Pants: passo 2, immagine 1 di 1
    • Next, iron the crease left previously by the seam.
    • Some fabrics cannot take high heat. Consult the tag of the garment for ironing instructions. Consider placing layers of fabric between the iron and garment to reduce heat.
  3. How to Lengthen Dress Pants: passo 3, immagine 1 di 1
    • Try on the pants. Have a partner pin the pants to the desired length.
    • If you do not have someone to help, measure the inseam of the pants and pin to the desired length.
  4. How to Lengthen Dress Pants: passo 4, immagine 1 di 1
    • Measure the width of the pant leg, double that measurement, and add 1.5 inches for seam allowance. Cut the bias tape to match this width.
  5. How to Lengthen Dress Pants: passo 5, immagine 1 di 1
    • Sew the bottom of the pant to the edge of the bias tape.
    • Make sure to remove pins while sewing as you move the work closer to the needle to avoid damaging the machine.
  6. How to Lengthen Dress Pants: passo 6, immagine 1 di 1
    • Fold the bias tape underneath (about 3/4" -1") and iron flat. Make sure that the bias tape is not visible. Pin the two layers together.
  7. How to Lengthen Dress Pants: passo 7, immagine 1 di 1
    • Sew the new seam of the pants.
    • If sewing with a machine, consult the machine's manual on how to do a blind stitch. If sewing by hand, use a tacking stitch. Make sure to only sew the two layers of fabric and not the entire pant-- this will cause the leg of your pants to not have an opening.
  8. How to Lengthen Dress Pants: passo 8, immagine 1 di 1
    • Repeat steps 1-7 for the other pant leg and iron flat.
Conclusione
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 13,867
