Salta al contenuto principale
How to JBL L40
Cosa ti serve
  1. How to JBL L40, How to JBL L40: passo 1, immagine 1 di 1
    • To remove the speaker from the cabinet, unscrew the 4 screws being careful not to slip and pierce the paper cone.
    • Once the screws are removed gently pull the speaker out of the cabinet.
    • There will be 2 wires attached to the speaker, remove them making sure to mark the polarity of them if they are not marked already.
  2. How to JBL L40: passo 2, immagine 1 di 1
    • Here is the speaker removed from the cabinet, you can clearly see the degraded state of the foam surround. Luckily this makes it very easy to remove it.
    • These next steps require careful attention to detail. Work slowly and carefully. You do not want to puncture/tear/rip the paper cone or any other components.
    • Remove the black foam ring.
    • Try to do as much of this by hand as you can. You do not want to damage the ring as you will need it for re assembly.
    • Carefully run your knife between the ring and the outer metal edge.
    • Now using your hands and knife when needed remove the black ring from the speaker frame. Prying slowly. Take care not to tear it.
    • Once the ring is removed rub all of the old foam surround off and set aside for reassembly
    • Remove all of the old foam surround from the cone and speaker frame. It was so crumbly on mine that all it took was a bunch of rubbing with my fingers. If you are having trouble use your knife, but again be careful.
  3. How to JBL L40: passo 5, immagine 1 di 1
    • You can see some of the glue seeped out, it will dry clear so don't worry.
  4. How to JBL L40: passo 6, immagine 1 di 1
    • Spread glue on the ring you removed earlier
    • place over the foam ring and press on securly
    • allow everything over night to dry completely.
  5. How to JBL L40: passo 7, immagine 1 di 1
    • Connect the wires to the speaker being mindfull of the polarity.
    • Gently fit the speaker into the housing
    • Line up the screws and progressively tighten them until the speaker is secured
Conclusione
Altre 4 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 19
Tutti i Tempi: 7,378
