Introduzione
This guide was written to help new guitar players take full control of their sound. Part of doing that is ensuring that your intonation is set so the notes you play remain in tune no matter where on the neck of the guitar you are fretting. This guide will show you both the process of intonation as well as my best practice for intonation which will save you time and money.
Cosa ti serve
Attach your guitar to your chromatic tuner using a 1/4" guitar cable, ensuring cable is completely inserted.
Connect your chromatic tuner to a power source (if necessary) and power it on.
After following this guide you should have a properly intonated electric guitar. No matter the note you should now be able to enjoy good tuning across all frets.
Altre 3 persone hanno completato questa guida.
Un commento
I always find that either the G, or the B string, is, slightly, out of tune, when I'm through, while playing and open cord against a bar chord of the same pitch. I've heard that this is an inherent problem in guitar; is there any work around for that?
