Introduzione
Keep your aging Mac from going obsolete by installing a patched version of macOS Ventura.
If you cannot Download MacOS Ventura on your Mac, download it after you installed OpenCore, as we will explain in step 11.
Cosa ti serve
If you're currently running macOS Mojave, click this link to find the Mojave installer in the App Store. For Catalina, click here.
Click Get or Download
In Terminal, type one of the following commands, depending on your version of macOS. (The name of the version of macOS, is the one you want to install on the key and downloaded.)
For El Capitan : sudo /Applications/Install\ OS\ X\ El\ Capitan.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume --applicationpath /Applications/Install\ OS\ X\ El\ Capitan.app
For Yosemite : sudo /Applications/Install\ OS\ X\ Yosemite.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume --applicationpath /Applications/Install\ OS\ X\ Yosemite.app
For Mavericks : sudo /Applications/Install\ OS\ X\ Mavericks.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume --applicationpath /Applications/Install\ OS\ X\ Mavericks.app
For Sierra : sudo /Applications/Install\ macOS\ Sierra.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume --applicationpath /Applications/Install\ macOS\ Sierra.app
Other versions, see the next step.
For High Sierra : sudo /Applications/Install\ macOS\ High\ Sierra.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume --applicationpath /Applications/Install\ macOS\ High\ Sierra.app
For Mojave : sudo /Applications/Install\ macOS\ Mojave.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume
For Catalina: sudo /Applications/Install\ macOS\ Catalina.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume
For Big Sur: sudo /Applications/Install\ macOS\ Big\ Sur.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume
For Monterey : sudo /Applications/Install\ macOS\ Monterey.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume
For Ventura : sudo /Applications/Install\ macOS\ Ventura.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume
Go to this link and check the last release of OpenCore Legacy Patcher. At the time of writing, it was version 0.6.5.
Scroll down the page until you find the Assets section of the latest release. Open it and download the file named OpenCore-Patcher-GUI.app.zip.
After the download ends, open the zip file to extract the OpenCore-Patcher app and open it.
If you do not have downloaded the MacOS installer of the version you wanted earlier, now you can use OpenCore to do so.
You can select Create macOS Installer to both download and create the USB installer for your selected version.
After you open the OpenCore-Patcher app, it will automatically recognize your Mac model and show it on the main menu window under the version of the patcher.
Check if your model is supported, and if everything works at this link.
Insert the other USB flash drive in your Mac and select Build and Install OpenCore.
After it finish to build your OpenCore configuration, select Install to Disk and then select the USB you just inserted.
You will then get prompted to insert your Mac password to continue.
After OpenCore finish the installation, you will get prompted to reboot.
While the Mac is rebooting, hold the option key to enter boot disk selection.
After you enter the boot disk selection, select EFI Boot disk (it is the lask USB you created).
Now select the MacOS Ventura installer and follow the usual MacOS install procedure.
After you finish to install MacOS, open again OpenCore Patcher and select Post Install Root Patch.
Then, select Start Root Patching.
OpenCore will ask you to relaunch as root. Select yes.
Then OpenCore will start patching your MacOS installation to make it compatible with your Mac.
After it finish to patch, it will ask you to reboot apply patches.
While your Mac reboots, hold down the [option] key to enter again boot disk selection. From there, select again EFI Boot and your Mac will start normally.
Now unplug all the USB drive that are still plugged in.
After your Mac boots into MacOS, open one last time OpenCore and select Build and Install OpenCore.
After it finish to build OpenCore, select Install to disk.
This time select disk0 to install OpenCore to your Mac internal drive, then select the EFI partition.
When it finish to install OpenCore, it will ask to reboot your Mac. While it reboots, hold down again the [option] key to enter one last time the boot disk selection.
After you enter the disk boot selection, hold down the [option] key and select the EFI disk to make this the default option.
Done! You succesfully installed Ventura on your Mac!
That’s it! You now have macOS Ventura installed on your Mac.
Un commento
I've been running this on an old Mac Mini Late 2012 semi-successfully. However it seems some menus get blurry and some apps none of the art elements will load. Guessing it's things that try to call on Metal. Anyone seen or aware of a fix for these bugs?
