Salta al contenuto principale
How to Install and Remove Tiles
Cosa ti serve
  1. How to Install and Remove Tiles, Remove the Front Panel: passo 1, immagine 1 di 3 How to Install and Remove Tiles, Remove the Front Panel: passo 1, immagine 2 di 3 How to Install and Remove Tiles, Remove the Front Panel: passo 1, immagine 3 di 3
    • Use your fingers to pull the Front Panel off the magnets securing it to the chassis.
  2. How to Install and Remove Tiles, Remove the Tiles: passo 2, immagine 1 di 3 How to Install and Remove Tiles, Remove the Tiles: passo 2, immagine 2 di 3 How to Install and Remove Tiles, Remove the Tiles: passo 2, immagine 3 di 3
    • Use your fingers to push the bottom of the Tile up and off the front panel and release its clips.
    • Remove the Tile.
  3. How to Install and Remove Tiles: passo 3, immagine 1 di 3 How to Install and Remove Tiles: passo 3, immagine 2 di 3 How to Install and Remove Tiles: passo 3, immagine 3 di 3
    • Repeat this procedure for the remaining tiles.
  4. How to Install and Remove Tiles, Install the Tiles: passo 4, immagine 1 di 3 How to Install and Remove Tiles, Install the Tiles: passo 4, immagine 2 di 3 How to Install and Remove Tiles, Install the Tiles: passo 4, immagine 3 di 3
    • Tiles can be installed in any orientation, even the ones with graphics.
    • Lay a Tile over an open slot on your Front Panel.
    • Use your fingers to press the tile into the slot and engage the clips.
    • You'll hear and feel an audible "click" when the clips engage.
  5. How to Install and Remove Tiles: passo 5, immagine 1 di 3 How to Install and Remove Tiles: passo 5, immagine 2 di 3 How to Install and Remove Tiles: passo 5, immagine 3 di 3
    • Install the remaining Tiles.
  6. How to Install and Remove Tiles: passo 6, immagine 1 di 3 How to Install and Remove Tiles: passo 6, immagine 2 di 3 How to Install and Remove Tiles: passo 6, immagine 3 di 3
    • Lay the bottom of the Front Panel on the small, protruding lip in the silver base to align its tabs.
    • Press the Front Panel flat to the chassis and let it align to the magnets.
Conclusione
If you need help, contact Framework support.
Alex Diaz-Kokaisl
Membro da: 01/16/22
212.557 Reputazione
1.039 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 177
