Salta al contenuto principale
How to Install and Remove Expansion Cards
Cosa ti serve
  1. How to Install and Remove Expansion Cards, Set your laptop down: passo 1, immagine 1 di 1
    • Set your laptop face-down on a clean work surface.
  2. How to Install and Remove Expansion Cards, Install an Expansion Card: passo 2, immagine 1 di 3 How to Install and Remove Expansion Cards, Install an Expansion Card: passo 2, immagine 2 di 3 How to Install and Remove Expansion Cards, Install an Expansion Card: passo 2, immagine 3 di 3
    • The next two steps show how to install an Expansion Card.
    • Slide an Expansion Card into an Expansion Card slot.
    • You don't need to unlock the latches to install the Expansion Cards—only when you want to remove them.
    • The Expansion Cards should click into place, and the front edge should be flush with the laptop.
  3. How to Install and Remove Expansion Cards: passo 3, immagine 1 di 2 How to Install and Remove Expansion Cards: passo 3, immagine 2 di 2
    • If there's a red bar showing under the Expansion Card latch, use your finger to flip the latch and lock the Expansion Card into its slot.
    • Locking the Expansion Card slots helps keep the cards in place when you unplug cables from them.
  4. How to Install and Remove Expansion Cards, Remove an Expansion Card: passo 4, immagine 1 di 2 How to Install and Remove Expansion Cards, Remove an Expansion Card: passo 4, immagine 2 di 2
    • The next two steps show how to remove an Expansion Card.
    • Use your fingers to flip the two Expansion Card latches (one for each side) into the unlocked position.
    • The latches display a red bar when they're unlocked.
  5. How to Install and Remove Expansion Cards: passo 5, immagine 1 di 3 How to Install and Remove Expansion Cards: passo 5, immagine 2 di 3 How to Install and Remove Expansion Cards: passo 5, immagine 3 di 3
    • Grip the lip of the Expansion Card with your fingers.
    • Pull the Expansion Card out of its slot and remove it.
    • If you have trouble pulling the Expansion Card out, you can also use the flat end of your Framework Screwdriver to push against the lip.
Conclusione
If you need help, contact Framework support.
Arthur Shi
Membro da: 01/03/18
310.120 Reputazione
701 Guide realizzate
Guide Team Membro di Guide Team
Staff
10 Membri
15.795 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 29
Tutti i Tempi: 321
