Salta al contenuto principale
How to Install a Fifth String Shubb Banjo Capo
Cosa ti serve
  1. How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: passo 1, immagine 1 di 3 How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: passo 1, immagine 2 di 3 How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: passo 1, immagine 3 di 3
    • Line the capo up along the fifth string side of the fretboard as shown.
    • Line the capo screw holes up about 12 mm from the fifth fret bar and about 4 mm from the face of the fret.
    • Be careful not to line the capo screw holes up directly below a fret bar or directly on top of a fret marker.
  2. How to Install a Fifth String Shubb Banjo Capo: passo 2, immagine 1 di 1
    • Use the marker to mark where the screws should go.
  3. How to Install a Fifth String Shubb Banjo Capo: passo 3, immagine 1 di 1
    • Use the drill to drill both holes for the two screws.
    • The holes should be drilled about 1 cm deep
    • You may need to borrow an extra pair of hands to help you stabilize the banjo while you perform this step.
  4. How to Install a Fifth String Shubb Banjo Capo: passo 4, immagine 1 di 2 How to Install a Fifth String Shubb Banjo Capo: passo 4, immagine 2 di 2
    • Use the flat head screw driver to insert and tighten the screws.
  5. How to Install a Fifth String Shubb Banjo Capo: passo 5, immagine 1 di 3 How to Install a Fifth String Shubb Banjo Capo: passo 5, immagine 2 di 3 How to Install a Fifth String Shubb Banjo Capo: passo 5, immagine 3 di 3
    • To use the capo, slide the capo finger down to the desired fret.
    • Then, tighten the spring knob.
Conclusione
For more information check out the Shubb fifth string capo website at: http://www.shubb.com/fs/index.html
Altre 6 persone hanno completato questa guida.
Sara Wier
Membro da: 02/24/15
263 Reputazione
1 Guida realizzata
Cal Poly, Team 23-4, Green Winter 2015 Membro di Cal Poly, Team 23-4, Green Winter 2015
CPSU-GREEN-W15S23G4
7 Membri
15 Guide realizzate
Un commento
thank you. Now, I know how to do and i décide to buy a shubb and to install it
Jean-Denis Del - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 38
Tutti i Tempi: 6,965
