Salta al contenuto principale
How to Install Scion tC LED Rear Fog Light
Cosa ti serve
  1. How to Install Scion tC LED Rear Fog Light, Rear Reflector: passo 1, immagine 1 di 3 How to Install Scion tC LED Rear Fog Light, Rear Reflector: passo 1, immagine 2 di 3 How to Install Scion tC LED Rear Fog Light, Rear Reflector: passo 1, immagine 3 di 3
    • Remove the screws holding the bulbless rear reflector in place and then remove the entire rear reflector assembly.
  2. How to Install Scion tC LED Rear Fog Light: passo 2, immagine 1 di 3 How to Install Scion tC LED Rear Fog Light: passo 2, immagine 2 di 3 How to Install Scion tC LED Rear Fog Light: passo 2, immagine 3 di 3
    • Carefully drill a hole using the drill bit included in the package. We recommend drilling directly in the center of the assembly, using the center raised portion as a guide line so the hole isn't misaligned.
    • Try to slightly shave down four corners of the socket in small increments so the socket can fit snugly in the housing.
  3. How to Install Scion tC LED Rear Fog Light: passo 3, immagine 1 di 2 How to Install Scion tC LED Rear Fog Light: passo 3, immagine 2 di 2
    • Install the socket into the housing. It should fit very tightly. If it is a little bit loose, you can apply some silicone glue around the outer corners of the socket to create a tighter seal.
  4. How to Install Scion tC LED Rear Fog Light: passo 4, immagine 1 di 2 How to Install Scion tC LED Rear Fog Light: passo 4, immagine 2 di 2
    • Remove any plastic clips that hold the rear plastic cover over the bottom of the trunk. Route the wires from the tail light assembly through the bumper and into the trunk area.
    • Remove any plastic clips and carpet that cover the driver side tail light assembly.
  5. How to Install Scion tC LED Rear Fog Light: passo 5, immagine 1 di 1
    • Locate the tail light and brake light mode wires. You will be tapping to these wires for power.
    • The color combo of the wires may differ among production batches, so we recommend that you double-check and test which wire is what function. You can easily test the socket by inserting the bulb and touching the wires directly to your car's battery. Mark which wire is the brighter mode, parking light mode, and negative.
    • Tap the negative wire from the socket to the ground and the black wire of the stock parking light.
    • Test to make sure everything works and reinstall all of the components that were removed for installation. Enjoy your new Scion tC LED 4th brake light!
Conclusione
Test to make sure your Scion tC LED rear fog light works and enjoy!
Eric Wu
Membro da: 01/21/15
3.534 Reputazione
23 Guide realizzate
1Commento della guida
This is for the wrong model Scion tC. Please edit the category and place in the 2014-15 category.
Zachary Nelson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 3,652
