Salta al contenuto principale
How to Hem a Dress
Cosa ti serve
  1. How to Hem a Dress, How to Hem a Dress: passo 1, immagine 1 di 2 How to Hem a Dress, How to Hem a Dress: passo 1, immagine 2 di 2
    • Begin with dress that is too long for the desired fit or style.
  2. How to Hem a Dress: passo 2, immagine 1 di 1
    • Lay the dress out flat, aligning the bottom seams.
    • Make sure any under layers are out of the way.
  3. How to Hem a Dress: passo 3, immagine 1 di 1
    • With a ruler, measure the amount you want the dress shortened.
    • After deciding, subtract 1" (25.4mm) from the seam allowance
    • (Ex: You want 3" (76.2mm) off, so you would measure 2'' (50.8mm) from the bottom of the fabric.)
  4. How to Hem a Dress: passo 4, immagine 1 di 1
    • Use chalk or pen to mark the measurement.
    • Make small dashed marks around the entire dress to ensure a consistent measurement.
  5. How to Hem a Dress: passo 5, immagine 1 di 1
    • Iron the dress flat.
  6. How to Hem a Dress: passo 6, immagine 1 di 1
    • Use scissors to cut vertically from the bottom seam to where you marked your measurement.
  7. How to Hem a Dress: passo 7, immagine 1 di 1
    • Then turn the scissors 90 degrees and begin cutting along the dashed lines you made in Step 4.
  8. How to Hem a Dress: passo 8, immagine 1 di 1
    • Then, again with the ruler and chalk measure 1/2'' (12.7 mm) from the raw edge of the fabric.
  9. How to Hem a Dress: passo 9, immagine 1 di 2 How to Hem a Dress: passo 9, immagine 2 di 2
    • Fold along the measurement you just made and iron it flat.
  10. How to Hem a Dress: passo 10, immagine 1 di 2 How to Hem a Dress: passo 10, immagine 2 di 2
    • Then fold again, one more time at 1/2''.
    • Lastly iron flat.
  11. How to Hem a Dress: passo 11, immagine 1 di 2 How to Hem a Dress: passo 11, immagine 2 di 2
    • Pin the fold in place.
    • Be careful when you pin.
  12. How to Hem a Dress: passo 12, immagine 1 di 1
    • If using a sewing machine, place it under the foot of the sewing machine.
    • Sew around the entire circumference of the dress.
    • Be careful when using a sewing machine.
  13. How to Hem a Dress: passo 13, immagine 1 di 3 How to Hem a Dress: passo 13, immagine 2 di 3 How to Hem a Dress: passo 13, immagine 3 di 3
    • Cut the threads and you're done!
Conclusione
Juliette Price
Membro da: 02/02/24
217 Reputazione
1 Guida realizzata
UC Davis, Team 3-5, Andersen Winter 2024 Membro di UC Davis, Team 3-5, Andersen Winter 2024
UCD-ANDERSEN-W24S3G5
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 19
Tutti i Tempi: 93
