Salta al contenuto principale
How to Fix an Overextending Holga 120N Camera Shutter
Cosa ti serve
  1. How to Fix an Overextending Holga 120N Camera Shutter, How to Fix an Overextending Holga 120N Camera Shutter: passo 1, immagine 1 di 2 How to Fix an Overextending Holga 120N Camera Shutter, How to Fix an Overextending Holga 120N Camera Shutter: passo 1, immagine 2 di 2
    • Slide the two metal lanyard locks up and off the camera.
    • Pop the back of the camera off.
  2. How to Fix an Overextending Holga 120N Camera Shutter: passo 2, immagine 1 di 2 How to Fix an Overextending Holga 120N Camera Shutter: passo 2, immagine 2 di 2
    • Remove the screw above the opening to the shutter piece using a Phillips #00 screwdriver.
    • Remove the screw below the opening to the shutter piece using a Phillips #00 screwdriver.
  3. How to Fix an Overextending Holga 120N Camera Shutter: passo 3, immagine 1 di 1
    • Pull the shutter piece out and away from the camera.
    • Pull the shutter piece away carefully to avoid snapping the wire.
  4. How to Fix an Overextending Holga 120N Camera Shutter: passo 4, immagine 1 di 3 How to Fix an Overextending Holga 120N Camera Shutter: passo 4, immagine 2 di 3 How to Fix an Overextending Holga 120N Camera Shutter: passo 4, immagine 3 di 3
    • Cut off the spade terminal's right prong with scissors.
  5. How to Fix an Overextending Holga 120N Camera Shutter: passo 5, immagine 1 di 1
    • Bend the spade terminal forward at a 90-degree angle.
  6. How to Fix an Overextending Holga 120N Camera Shutter: passo 6, immagine 1 di 2 How to Fix an Overextending Holga 120N Camera Shutter: passo 6, immagine 2 di 2
    • Slice the blue plastic off of the spade terminal with the boxcutter/Exacto-knife.
    • The plastic bottom is sealed on very tightly. Use caution when cutting it away!
    • Remove the plastic from the spade terminal.
  7. How to Fix an Overextending Holga 120N Camera Shutter: passo 7, immagine 1 di 3 How to Fix an Overextending Holga 120N Camera Shutter: passo 7, immagine 2 di 3 How to Fix an Overextending Holga 120N Camera Shutter: passo 7, immagine 3 di 3
    • Place hot glue at the bottom of the spade terminal.
    • Place the spade terminal in the small hole underneath the shutter.
    • Point the spade terminal horizontally, facing the wire that leads back to the camera.
  8. How to Fix an Overextending Holga 120N Camera Shutter: passo 8, immagine 1 di 1
    • Screw the shutter piece back into place using a Phillips #00 screwdriver.
  9. How to Fix an Overextending Holga 120N Camera Shutter: passo 9, immagine 1 di 2 How to Fix an Overextending Holga 120N Camera Shutter: passo 9, immagine 2 di 2
    • Return the back of the camera into place.
Conclusione
You’ve now learned the following:
  • How to disassemble and reassemble a Holga 120N camera
  • How to add a spade terminal as a blocker
The spade terminal will stop the overextended shutter. Enjoy taking pictures!
Jacob DeLany
Membro da: 09/28/21
169 Reputazione
1 Guida realizzata
Un commento
That's a PZ1 bit which gets the screws out easily. If you got the screws out with a PH00 bit, either they changed the way the camera is made before mine was made or you are quite tenacious in your screwdriving.
s l - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 56
Tutti i Tempi: 1,354
