Salta al contenuto principale
How to Fix a Thrustmaster Eswap X Pro Controller Trigger
Cosa ti serve
  1. How to Fix a Thrustmaster Eswap X Pro Controller Trigger, How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 1, immagine 1 di 2 How to Fix a Thrustmaster Eswap X Pro Controller Trigger, How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 1, immagine 2 di 2
    • Flip the controller so the backside is facing up.
    • Flip both of the switches away from the center.
  2. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 2, immagine 1 di 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 2, immagine 2 di 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 2, immagine 3 di 3
    • Flip the controller over so the top is facing up.
    • Pull out both the joystick and the directional pad modules.
  3. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 3, immagine 1 di 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 3, immagine 2 di 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 3, immagine 3 di 3
    • Flip the controller over again so the backside is facing up.
    • Use a spudger to remove five rubber screw covers.
  4. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 4, immagine 1 di 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 4, immagine 2 di 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 4, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove each of the 4.0 mm exposed screws.
  5. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 5, immagine 1 di 2 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 5, immagine 2 di 2
    • Use a Phillips #1 screwdriver to loosen the captive screw and remove the trigger button.
  6. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 6, immagine 1 di 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 6, immagine 2 di 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 6, immagine 3 di 3
    • Rotate the controller 90 degrees.
    • Pull off the magnetic side cover.
  7. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 7, immagine 1 di 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 7, immagine 2 di 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 7, immagine 3 di 3
    • Lift the back cover slightly from where you removed the trigger button.
    • Use a Q-tip dipped with isopropyl alcohol to clean the surrounding area.
    • Additionally, wipe down the top face of the trigger with a Q-tip.
  8. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 8, immagine 1 di 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 8, immagine 2 di 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 8, immagine 3 di 3
    • Reattach the trigger button onto the controller.
    • Use a Phillips #1 screwdriver to tighten the screw securing trigger button.
  9. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 9, immagine 1 di 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 9, immagine 2 di 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 9, immagine 3 di 3
    • Use a Phillips #1 screwdriver to reattach the 4.0 mm screws to the back of the controller.
  10. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 10, immagine 1 di 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 10, immagine 2 di 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 10, immagine 3 di 3
    • Notice that the notches on the rubber covers correspond with the notches on the screw hole.
    • Reattach the rubber covers above the screws.
  11. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 11, immagine 1 di 1
    • Place the joystick and the directional pad modules back in their respective spots.
  12. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 12, immagine 1 di 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 12, immagine 2 di 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: passo 12, immagine 3 di 3
    • Reattach the magnetic side cover.
    • The controller is fixed!
Conclusione
Altre 3 persone hanno completato questa guida.
Laurence Chan
Membro da: 01/26/23
268 Reputazione
1 Guida realizzata
UC Davis, Team 2-3, Morris Winter 2023 Membro di UC Davis, Team 2-3, Morris Winter 2023
UCD-MORRIS-W23S2G3
2 Membri
1 Guida realizzata
3Commenti sulla guida
The problem is it keeps happening after doing all these steps. is there any way or parts to replace the trigger sensor completely? Possibly with a nice hall effect sensor?
John Addington - Replica
You can remove the lever bar that goes from the screw to the sensor (the one you see on Step 7)
Spray a small amount of WD40 on the sensor and use a prong to rotate the part on its full range of motion several times, that will clean up the contact inside and it completely fixed the jitter on mine.
Alex L -
hi, i made an account here just to say this worked for me but on the thrustmaster eswap S pro controller, it's almost identical aside from the cover panels
Anna Fiore - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 39
Ultimi 30 Giorni: 122
Tutti i Tempi: 4,224
