Salta al contenuto principale
How to Fix a T-shirt That's Too Big
Cosa ti serve
  1. How to Fix a T-shirt That's Too Big, How to Fix a T-shirt That's Too Big: passo 1, immagine 1 di 2 How to Fix a T-shirt That's Too Big, How to Fix a T-shirt That's Too Big: passo 1, immagine 2 di 2
    • Lay the larger T-shirt on a flat surface.
    • Make sure it sits perfectly flat and your side seams are in line.
    • Take another T-shirt that fits you perfectly and lay it on top of the larger T-shirt.
    • Double-check that the neckline is straight and the graphic on the larger T-shirt has plenty of room on either side.
  2. How to Fix a T-shirt That's Too Big: passo 2, immagine 1 di 1
    • Use a water-soluble fabric marker to trace the small T-shirt out on the larger one.
    • Leave some fabric allowance in case you need to fix anything or make adjustments.
  3. How to Fix a T-shirt That's Too Big: passo 3, immagine 1 di 1
    • Use scissors to cut off the excess material.
    • This will divide the shirt into three pieces: the body and two sleeves. Make sure to leave some seam allowance to make adjustments, if needed.
  4. How to Fix a T-shirt That's Too Big: passo 4, immagine 1 di 1
    • Using pins, put the sleeves together in order to give a crease.
    • Pin the rest of the unsewn edges to get a rough idea of whether it is the correct size.
  5. How to Fix a T-shirt That's Too Big: passo 5, immagine 1 di 1
    • Use your sewing machine to sew the parts of the shirt together.
    • Go back over with a smaller stitch to secure the parts of the shirt.
    • This guide uses white thread for visibility. Use a matching thread unless you want contrasting colors. Sew on the inside of the T-shirt to hide your seams.
  6. How to Fix a T-shirt That's Too Big: passo 6, immagine 1 di 1
    • Use scissors to cut any extra threads left over from the project.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
lakshay
Membro da: 09/26/22
154 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 176
Tutti i Tempi: 580
