Salta al contenuto principale
How to Fix a Sweater Snag
Cosa ti serve
  1. How to Fix a Sweater Snag, How to Fix a Sweater Snag: passo 1, immagine 1 di 2 How to Fix a Sweater Snag, How to Fix a Sweater Snag: passo 1, immagine 2 di 2
    • Using scissors, cut thread that matches the color of your sweater.
  2. How to Fix a Sweater Snag: passo 2, immagine 1 di 2 How to Fix a Sweater Snag: passo 2, immagine 2 di 2
    • Pull thread through the needle and tie a knot at the end of the needle.
  3. How to Fix a Sweater Snag: passo 3, immagine 1 di 1
    • Lay your sweater out on a smooth surface.
  4. How to Fix a Sweater Snag: passo 4, immagine 1 di 1
    • Identify the snag from the inside of your sweater.
  5. How to Fix a Sweater Snag: passo 5, immagine 1 di 2 How to Fix a Sweater Snag: passo 5, immagine 2 di 2
    • Pull the needle through the sweater at the site of the snag, ensuring that the needle is facing the inside of the sweater.
    • Ensure that you have enough thread to work with.
  6. How to Fix a Sweater Snag: passo 6, immagine 1 di 2 How to Fix a Sweater Snag: passo 6, immagine 2 di 2
    • Loop the snag around the needle.
    • Begin to pull the needle through the snag to the other side.
  7. How to Fix a Sweater Snag: passo 7, immagine 1 di 2 How to Fix a Sweater Snag: passo 7, immagine 2 di 2
    • Once again, face the needle towards the inside of the sweater then pull the needle through the site of snag.
  8. How to Fix a Sweater Snag: passo 8, immagine 1 di 2 How to Fix a Sweater Snag: passo 8, immagine 2 di 2
    • Cut the loose thread.
    • Make sure there is enough thread sticking out from where the snag was.
  9. How to Fix a Sweater Snag: passo 9, immagine 1 di 1
    • Identify the site of the snag to ensure steps were followed correctly.
  10. How to Fix a Sweater Snag: passo 10, immagine 1 di 1
    • Steam the sweater at the site of the snag to secure the fix in place.
Conclusione
Hannah Ziebell
Membro da: 02/20/24
181 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 73
Ultimi 30 Giorni: 255
Tutti i Tempi: 1,624
