Salta al contenuto principale
How to Fix a Squeaky Bed Frame
Cosa ti serve
  1. How to Fix a Squeaky Bed Frame, How to Fix a Squeaky Bed Frame: passo 1, immagine 1 di 1
    • Remove anything that is on the bed frame.
  2. How to Fix a Squeaky Bed Frame: passo 2, immagine 1 di 1
    • Shake the bed frame to pinpoint the area of noise.
  3. How to Fix a Squeaky Bed Frame: passo 3, immagine 1 di 1
    • Identify which type of screw the bedframe uses in the given area.
    • You will need to make use of the corresponding screwdriver throughout the guide.
    • Typically, the bed frame will use the same type of screws throughout.
  4. How to Fix a Squeaky Bed Frame: passo 4, immagine 1 di 1
    • Ensure the components of the bed frame are aligned.
    • Identify gaps between parts of the frame.
    • Tighten the screws where gaps are present
    • Sometimes mismatched components cause squeakiness.
  5. How to Fix a Squeaky Bed Frame: passo 5, immagine 1 di 1
    • Tighten the screws within the area of noise.
    • It is recommended to retighten all the screws to avoid any future squeakiness but it is not required.
  6. How to Fix a Squeaky Bed Frame: passo 6, immagine 1 di 1
    • Spray WD-40 into all the contact points of the bed frame.
    • This includes screws and intersections of the frame.
    • Be careful of the spray around children and your eyes.
  7. How to Fix a Squeaky Bed Frame: passo 7, immagine 1 di 1
    • This is an alternative for the previous step.
    • If WD-40 is not available, using a q-tip dipped in a vegetable oil (or a comparable oil that is available) can be used to lubricate the contact points.
Conclusione
Reassemble the bed to your liking.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 72
Tutti i Tempi: 1,082
