Salta al contenuto principale
How to Fix a Skewed Wheel on a Children's Kick Scooter
Cosa ti serve
  1. How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 1, immagine 1 di 3 How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 1, immagine 2 di 3 How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 1, immagine 3 di 3
    • Remove the two bottom 16 mm pan head screws using a Phillips #1 screwdriver.
  2. How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 2, immagine 1 di 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 2, immagine 2 di 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 2, immagine 3 di 3
    • Remove the two 12 mm button head screws on top using a 4 mm Allen wrench.
  3. How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 3, immagine 1 di 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 3, immagine 2 di 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 3, immagine 3 di 3
    • Remove the plastic case from the base of the scooter.
  4. How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 4, immagine 1 di 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 4, immagine 2 di 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 4, immagine 3 di 3
    • Carefully pull the sides of the wheels up and remove them from the spring.
  5. How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 5, immagine 1 di 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 5, immagine 2 di 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 5, immagine 3 di 3
    • Grab the spring with combination pliers and bend it into a straight position.
    • Don't bend the spring too much as it could snap and replacement would be needed.
  6. How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 6, immagine 1 di 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 6, immagine 2 di 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 6, immagine 3 di 3
    • Insert the spring into the center section of the wheels.
    • Slide the two rings on the sides of the wheels into the two rods.
  7. How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 7, immagine 1 di 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 7, immagine 2 di 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 7, immagine 3 di 3
    • Insert the plastic case back into its original position.
  8. How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 8, immagine 1 di 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 8, immagine 2 di 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 8, immagine 3 di 3
    • Insert and tighten the two 12 mm button head screws on top using a 4 mm Allen wrench.
  9. How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 9, immagine 1 di 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 9, immagine 2 di 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: passo 9, immagine 3 di 3
    • Replace the two bottom 16 mm pan head screws using a Phillips #1 screwdriver.
Linea Traguardo
Amir Issagali
Membro da: 01/10/21
169 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 33
Tutti i Tempi: 1,450
