Salta al contenuto principale
How to Fix a Ripped Stuffed Animal
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. How to Fix a Ripped Stuffed Animal, How to Fix a Ripped Stuffed Animal: passo 1, immagine 1 di 3 How to Fix a Ripped Stuffed Animal, How to Fix a Ripped Stuffed Animal: passo 1, immagine 2 di 3 How to Fix a Ripped Stuffed Animal, How to Fix a Ripped Stuffed Animal: passo 1, immagine 3 di 3
    • Use Polyester Fiberfill stuffing to fill the stuffed bear via rip. Add more stuffing for a firmer toy.
    • Do not overfill the toy, or it may rip again.
  2. How to Fix a Ripped Stuffed Animal: passo 2, immagine 1 di 1
    • Insert a thread through the eye of the needle (the hole) and tie it tightly to the needle.
  3. How to Fix a Ripped Stuffed Animal: passo 3, immagine 1 di 1
    • Make a knot at the loose end of the thread.
    • This is so that the thread doesn't slip through the cloth while sewing up the bear.
  4. How to Fix a Ripped Stuffed Animal: passo 4, immagine 1 di 3 How to Fix a Ripped Stuffed Animal: passo 4, immagine 2 di 3 How to Fix a Ripped Stuffed Animal: passo 4, immagine 3 di 3
    • Push needle through the end of the rip.
    • Continue along the seam, putting the needle through both sides of the rip to create a stitch.
  5. How to Fix a Ripped Stuffed Animal: passo 5, immagine 1 di 2 How to Fix a Ripped Stuffed Animal: passo 5, immagine 2 di 2
    • After the rip is sewn shut, tie the end of the thread by creating a knot
    • Create the knot by wrapping the thread around the needle several times Then pull the thread through to secure the knot at the base.
    • Once is enough, but for more security, you can repeat this step twice.
  6. How to Fix a Ripped Stuffed Animal: passo 6, immagine 1 di 3 How to Fix a Ripped Stuffed Animal: passo 6, immagine 2 di 3 How to Fix a Ripped Stuffed Animal: passo 6, immagine 3 di 3
    • Cut any excess thread and you're done!
    • Enjoy your repaired stuffed bear!
Conclusione
Megan Nash
Membro da: 01/19/16
108 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 215
