Salta al contenuto principale
How to Fix a Ripped Shirt Hem
Cosa ti serve
  1. How to Fix a Ripped Shirt Hem, How to Fix a Ripped Shirt Hem: passo 1, immagine 1 di 3 How to Fix a Ripped Shirt Hem, How to Fix a Ripped Shirt Hem: passo 1, immagine 2 di 3 How to Fix a Ripped Shirt Hem, How to Fix a Ripped Shirt Hem: passo 1, immagine 3 di 3
    • Turn your shirt inside out.
    • Find your shirt's ripped hem.
    • If the shirt has any loose strings, trim them.
  2. How to Fix a Ripped Shirt Hem: passo 2, immagine 1 di 1
    • Iron the area of the shirt where the hem is ripped.
    • If the hem is ripped several inches, you might want to insert sewing pins to keep the fabric in place.
    • It's important to iron because it allows for easier sewing when the shirt stays folded the same way as the non-ripped part of the hem.
    • The iron will be very hot. Be careful as to not burn yourself.
  3. How to Fix a Ripped Shirt Hem: passo 3, immagine 1 di 1
    • Acquire a sewing needle and thread.
    • Take your thread and loop it through the eye of the needle, the hole at the end of the needle.
    • You'll want the thread to be the same color and shade as the original thread. For visual purposes, I will use red in place of black.
    • The needle is sharp.
  4. How to Fix a Ripped Shirt Hem: passo 4, immagine 1 di 1
    • Pull the thread through the needle so that there is an equal length on each side of the needle.
    • Tie the end of the thread together by making a knot.
    • Making an additional knot over the first makes it more secure.
  5. How to Fix a Ripped Shirt Hem: passo 5, immagine 1 di 1
    • Starting on the inside of the shirt, poke the needle through toward the side that is right-side-out.
    • Sew over the original thread for about half an inch to ensure that it's thread won't rip again.
  6. How to Fix a Ripped Shirt Hem: passo 6, immagine 1 di 1
    • Once the needle and thread is pulled through the side that is right-side-out, you will push it back through as close to the original hole as you can.
    • Doing this will make the visible hem as hidden as possible.
  7. How to Fix a Ripped Shirt Hem: passo 7, immagine 1 di 3 How to Fix a Ripped Shirt Hem: passo 7, immagine 2 di 3 How to Fix a Ripped Shirt Hem: passo 7, immagine 3 di 3
    • When you're back on the inside of the hem, make the next stitch a couple millimeters over and diagonal from the first.
  8. How to Fix a Ripped Shirt Hem: passo 8, immagine 1 di 2 How to Fix a Ripped Shirt Hem: passo 8, immagine 2 di 2
    • Continue this pattern so that the inside has diagonal stitches, and the outside has small, staggered dots.
  9. How to Fix a Ripped Shirt Hem: passo 9, immagine 1 di 3 How to Fix a Ripped Shirt Hem: passo 9, immagine 2 di 3 How to Fix a Ripped Shirt Hem: passo 9, immagine 3 di 3
    • Finish sewing the hem. Make sure the last stitch is on the inside of the shirt.
    • Make a knot where you intend for the pattern to stop.
    • It's important to tie the knot as close to the fabric as possible. Doing this secures the stitching.
  10. How to Fix a Ripped Shirt Hem: passo 10, immagine 1 di 1
    • Cut off excess thread.
Linea Traguardo
Altre 4 persone hanno completato questa guida.
Kaitlyn Adams
Membro da: 09/29/15
247 Reputazione
1 Guida realizzata
Cal Poly, Team 17-5, Green Fall 2015 Membro di Cal Poly, Team 17-5, Green Fall 2015
CPSU-GREEN-F15S17G5
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 45
Tutti i Tempi: 11,534
