Salta al contenuto principale
How to Fix a Razer Naga Trinity Click Button
Cosa ti serve
  1. How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: passo 1, immagine 1 di 3 How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: passo 1, immagine 2 di 3 How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: passo 1, immagine 3 di 3
    • Remove the three pads from the bottom of the mouse.
    • Remove the four screws beneath the pads using a JIS #1 screwdriver.
  2. How to Fix a Razer Naga Trinity Click Button: passo 2, immagine 1 di 2 How to Fix a Razer Naga Trinity Click Button: passo 2, immagine 2 di 2
    • Press the top of mouse and pull back to disconnect the mouse shell.
    • Pull out the cord that connects the RGB button.
  3. How to Fix a Razer Naga Trinity Click Button: passo 3, immagine 1 di 2 How to Fix a Razer Naga Trinity Click Button: passo 3, immagine 2 di 2
    • Remove the right shell.
    • Disconnect the cable connecting the left shell to the mouse.
    • Remove the left shell.
  4. How to Fix a Razer Naga Trinity Click Button: passo 4, immagine 1 di 1
    • Use a safety pin to unlatch the clicker buttons.
  5. How to Fix a Razer Naga Trinity Click Button: passo 5, immagine 1 di 2 How to Fix a Razer Naga Trinity Click Button: passo 5, immagine 2 di 2
    • Insert the open safety pin to lift one side latch slightly.
    • Do not open the whole part.
    • Repeat for the other side.
  6. How to Fix a Razer Naga Trinity Click Button: passo 6, immagine 1 di 3 How to Fix a Razer Naga Trinity Click Button: passo 6, immagine 2 di 3 How to Fix a Razer Naga Trinity Click Button: passo 6, immagine 3 di 3
    • Remove the clicker and white pin.
    • Gently press the middle part of the copper sheet until it unhooks itself.
    • Pull the bended part of the copper sheet back.
  7. How to Fix a Razer Naga Trinity Click Button: passo 7, immagine 1 di 1
    • Reassemble the copper sheet with the white pin seated properly.
    • Push the spring down into its place using a spudger.
    • You will hear a click sound if you successfully assemble it.
Conclusione
Altre 4 persone hanno completato questa guida.
Haoran Ke
Membro da: 01/13/22
283 Reputazione
1 Guida realizzata
1Commento della guida
On the latest version of the mouse, the clicker button can no longer be opened...
Jérémie PLAYOUT - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 37
Ultimi 30 Giorni: 287
Tutti i Tempi: 14,014
