Salta al contenuto principale
How to Fix a Papasan Chair Base
Cosa ti serve
  1. How to Fix a Papasan Chair Base, How to Fix a Papasan Chair Base: passo 1, immagine 1 di 2 How to Fix a Papasan Chair Base, How to Fix a Papasan Chair Base: passo 1, immagine 2 di 2
    • Remove and save rattan from broken sections.
  2. How to Fix a Papasan Chair Base: passo 2, immagine 1 di 1
    • Remove old nails from the sections that have separated. Pliers may be helpful for nails that are hard to reach with the claw of a hammer.
  3. How to Fix a Papasan Chair Base: passo 3, immagine 1 di 2 How to Fix a Papasan Chair Base: passo 3, immagine 2 di 2
    • Glue the split wood pieces together, clamp, and let them dry.
  4. How to Fix a Papasan Chair Base: passo 4, immagine 1 di 1
    • Nail the thin decorative wood pieces to the larger sections of the frame.
  5. How to Fix a Papasan Chair Base: passo 5, immagine 1 di 1
    • Screw the circular base and upper to the vertical supports that have become disconnected.
  6. How to Fix a Papasan Chair Base: passo 6, immagine 1 di 1
    • Screw together two ends of the circular part of the frame. Align the screw to be perpendicular to the seam where the two ends connect.
  7. How to Fix a Papasan Chair Base: passo 7, immagine 1 di 2 How to Fix a Papasan Chair Base: passo 7, immagine 2 di 2
    • Nail down one side of the rattan and re-wrap it. Finish by nailing down the other end of the rattan to secure it.
Conclusione
Following these steps will restore your papasan chair to working order.
Altre 6 persone hanno completato questa guida.
3 Commenti
What screw you used? Screw dimensions?
Lourdes Diaz - Replica
easy peasy…thanks
Katherine Elaine - Replica
Were u would u recommend get the wicker to wrap chairs , at???
Thanks in advance!!!
Carrmone Bears - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 76
Ultimi 30 Giorni: 329
Tutti i Tempi: 17,308
