Salta al contenuto principale
How to Fix a Non-Sticky Cutting Mat
Cosa ti serve
  1. How to Fix a Non-Sticky Cutting Mat, How to Fix a Non-Sticky Cutting Mat: passo 1, immagine 1 di 1
    • Place the non-sticky mat on a flat surface.
  2. How to Fix a Non-Sticky Cutting Mat: passo 2, immagine 1 di 1
    • Spray the non-sticky cutting mat with a spray cleaner covering the entire mat.
  3. How to Fix a Non-Sticky Cutting Mat: passo 3, immagine 1 di 1
    • Let it sit for 5-10 minutes.
  4. How to Fix a Non-Sticky Cutting Mat: passo 4, immagine 1 di 1
    • Use a scraper to gently push the dirt off the mat that is causing your cutting mat not to be sticky.
  5. How to Fix a Non-Sticky Cutting Mat: passo 5, immagine 1 di 1
    • Once all the dirt is removed, let it air dry.
  6. How to Fix a Non-Sticky Cutting Mat: passo 6, immagine 1 di 1
    • Once dry, make sure to cover the cutting mat with its plastic cover to avoid the dust sticking to it.
Linea Traguardo
April Pantaleon
Membro da: 09/20/20
349 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 20
Tutti i Tempi: 364
