Salta al contenuto principale
How to Fix a Noisy/Squeaky Bicycle Chain
Cosa ti serve
  1. How to Fix a Noisy/Squeaky Bicycle Chain, How to Fix a Noisy/Squeaky Bicycle Chain: passo 1, immagine 1 di 3 How to Fix a Noisy/Squeaky Bicycle Chain, How to Fix a Noisy/Squeaky Bicycle Chain: passo 1, immagine 2 di 3 How to Fix a Noisy/Squeaky Bicycle Chain, How to Fix a Noisy/Squeaky Bicycle Chain: passo 1, immagine 3 di 3
    • Place a piece of cardboard under the bicycle to catch excess cleaner.
    • Rotate the foot pedal with your hand slowly, and spray WD-40 bicycle chain cleaner evenly throughout the chain.
    • Only use WD-40 that is specifically made for bicycles. Using normal WD-40 can damage your bicycle chain.
    • The chemical spray is toxic and very unpleasant to smell. Please use a mask or other means of protection on your face and eyes.
  2. How to Fix a Noisy/Squeaky Bicycle Chain: passo 2, immagine 1 di 3 How to Fix a Noisy/Squeaky Bicycle Chain: passo 2, immagine 2 di 3 How to Fix a Noisy/Squeaky Bicycle Chain: passo 2, immagine 3 di 3
    • Use bicycle cleaning tools to clean the bicycle chain, the chainrings, the cogset, and front & rear derailleurs until most of the rust is gone.
    • Some bicycles do not have all of these parts.
  3. How to Fix a Noisy/Squeaky Bicycle Chain: passo 3, immagine 1 di 2 How to Fix a Noisy/Squeaky Bicycle Chain: passo 3, immagine 2 di 2
    • Check your chain system, not only on the chain, but also on the chainrings, cogset, and derailleur system. Sometimes this part will also make noises because of rust.
    • Drip the WD-40 bicycle lubricant on one spot of the chain and rotate the foot pedal until the whole chain is lubricated.
    • Repeat this process until the chain no longer squeaks.
Linea Traguardo
Jiaming Liu
Membro da: 09/19/20
97 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 24
Tutti i Tempi: 2,462
