Salta al contenuto principale
How to Fix a Loose Louver in Wooden Sliding Shutters
Cosa ti serve
  1. How to Fix a Loose Louver in Wooden Sliding Shutters, How to Fix a Loose Louver in Wooden Sliding Shutters: passo 1, immagine 1 di 1
    • Clean the louvers with the disinfectant wipes.
  2. How to Fix a Loose Louver in Wooden Sliding Shutters: passo 2, immagine 1 di 1
    • Locate the broken or loose louver.
  3. How to Fix a Loose Louver in Wooden Sliding Shutters: passo 3, immagine 1 di 2 How to Fix a Loose Louver in Wooden Sliding Shutters: passo 3, immagine 2 di 2
    • Align the louvers so they are parallel to the ground.
    • Make sure the knob is facing the tilt bar NOT away from it.
  4. How to Fix a Loose Louver in Wooden Sliding Shutters: passo 4, immagine 1 di 1
    • Tilt the louver down creating a 30 degree angle with the bar.
  5. How to Fix a Loose Louver in Wooden Sliding Shutters: passo 5, immagine 1 di 1
    • Position the knob in between the two holes.
  6. How to Fix a Loose Louver in Wooden Sliding Shutters: passo 6, immagine 1 di 1
    • Insert the pin into the two holes.
  7. How to Fix a Loose Louver in Wooden Sliding Shutters: passo 7, immagine 1 di 2 How to Fix a Loose Louver in Wooden Sliding Shutters: passo 7, immagine 2 di 2
    • Push and secure the pin.
  8. How to Fix a Loose Louver in Wooden Sliding Shutters: passo 8, immagine 1 di 2 How to Fix a Loose Louver in Wooden Sliding Shutters: passo 8, immagine 2 di 2
    • You are finished!
Linea Traguardo
Fatima Sakhri
Membro da: 05/08/20
157 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,413
