Salta al contenuto principale
How to Fix a Jammed Key on a Logitech K120
Cosa ti serve
  1. How to Fix a Jammed Key on a Logitech K120, How to Fix a Jammed Key on a Logitech K120: passo 1, immagine 1 di 2 How to Fix a Jammed Key on a Logitech K120, How to Fix a Jammed Key on a Logitech K120: passo 1, immagine 2 di 2
    • Unplug the keyboard to prevent accidental damage.
  2. How to Fix a Jammed Key on a Logitech K120: passo 2, immagine 1 di 3 How to Fix a Jammed Key on a Logitech K120: passo 2, immagine 2 di 3 How to Fix a Jammed Key on a Logitech K120: passo 2, immagine 3 di 3
    • Gently remove the keycap using a keycap puller/screwdriver/nylon spudger, or a plastic opening tool. Inspect for dirt, dust, or misalignment.
    • Avoid using excessive force to prevent damage.
  3. How to Fix a Jammed Key on a Logitech K120: passo 3, immagine 1 di 1
    • Clean the area under the key using compressed air, a microfiber cloth, or a cotton swab for detailed cleaning.
  4. How to Fix a Jammed Key on a Logitech K120: passo 4, immagine 1 di 3 How to Fix a Jammed Key on a Logitech K120: passo 4, immagine 2 di 3 How to Fix a Jammed Key on a Logitech K120: passo 4, immagine 3 di 3
    • Examine the stabilizer and ensure it is properly attached.
  5. How to Fix a Jammed Key on a Logitech K120: passo 5, immagine 1 di 1
    • Test the switch by pressing it without the keycap (you can press it with a cotton swab).
  6. How to Fix a Jammed Key on a Logitech K120: passo 6, immagine 1 di 2 How to Fix a Jammed Key on a Logitech K120: passo 6, immagine 2 di 2
    • Reattach the keycap by aligning it properly and pressing it down firmly but gently to avoid damaging the switch.
  7. How to Fix a Jammed Key on a Logitech K120: passo 7, immagine 1 di 2 How to Fix a Jammed Key on a Logitech K120: passo 7, immagine 2 di 2
    • Test the key’s functionality by typing in a text editor or keyboard tester to ensure proper response. If the issue persists, repeat cleaning steps.
Linea Traguardo
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 27
Tutti i Tempi: 271
