Salta al contenuto principale
How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line
Cosa ti serve
  1. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line, How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: passo 1, immagine 1 di 1
    • Move the dial to a vertical position to close the fuel line.
    • This will prevent fluids from continuing to move freely throughout the lawnmower.
  2. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: passo 2, immagine 1 di 3 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: passo 2, immagine 2 di 3 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: passo 2, immagine 3 di 3
    • Use the screwdriver to push the right tension pin to the right so the hose can be removed.
    • Remove the right hose by wiggling the screwdriver between the hose and the tube where it is attached.
    • Have the empty bottle ready to use as soon as the hose is detached from the fuel line.
  3. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: passo 3, immagine 1 di 1
    • Place the hose into a bottle to catch the leaking fluid from the fuel tank.
    • More liquid will be released from the right hose than in any other part of the process.
  4. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: passo 4, immagine 1 di 3 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: passo 4, immagine 2 di 3 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: passo 4, immagine 3 di 3
    • Move the tension pin to the left to allow the hose to be removed.
    • Remove the left hose and catch the fluids that leak out.
  5. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: passo 5, immagine 1 di 2 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: passo 5, immagine 2 di 2
    • Remove the 10 mm bolt holding the carburetor fuel cup in place.
    • Remove the carburetor fuel cup
    • Use the rag to clean the inside of the carburetor fuel cup after it has been removed.
    • Let any fluid released from removing the carburetor spill onto the rag.
  6. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: passo 6, immagine 1 di 1
    • Tilt the lawnmower forward so any remaining fluids can make their way out.
  7. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: passo 7, immagine 1 di 1
    • Place the detached hoses back to the fuel line.
    • Move the pins back to the end of the hose to hold them in place.
  8. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: passo 8, immagine 1 di 1
    • Use the fuel can to refill the lawnmower now that the contaminated fuel has been removed.
  9. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: passo 9, immagine 1 di 1
    • Turn the dial to a horizontal position to reopen the fuel line.
Conclusione
With the water out of the fuel line, the lawnmower should be ready for use.
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 102
Tutti i Tempi: 1,813
