Salta al contenuto principale
How to Fix a Hole in a Pant Pocket
Cosa ti serve
  1. How to Fix a Hole in a Pant Pocket, How to Fix a Hole in a Pant Pocket: passo 1, immagine 1 di 2 How to Fix a Hole in a Pant Pocket, How to Fix a Hole in a Pant Pocket: passo 1, immagine 2 di 2
    • Flip the pocket inside out.
  2. How to Fix a Hole in a Pant Pocket: passo 2, immagine 1 di 2 How to Fix a Hole in a Pant Pocket: passo 2, immagine 2 di 2
    • Carefully align the ripped part of the pocket together.
  3. How to Fix a Hole in a Pant Pocket: passo 3, immagine 1 di 3 How to Fix a Hole in a Pant Pocket: passo 3, immagine 2 di 3 How to Fix a Hole in a Pant Pocket: passo 3, immagine 3 di 3
    • Put a sewing pin into a stable piece of fabric to make a hole.
    • Carefully remove the pins.
  4. How to Fix a Hole in a Pant Pocket: passo 5, immagine 1 di 3 How to Fix a Hole in a Pant Pocket: passo 5, immagine 2 di 3 How to Fix a Hole in a Pant Pocket: passo 5, immagine 3 di 3
    • Carefully insert the a threaded sewing needle into the hole you created at one end of the tear.
    • Sew along the length of the tear, joining the two pieces of fabric together.
    • Be very careful when using needle as the point can be very sharp and lead to injury.
  5. How to Fix a Hole in a Pant Pocket: passo 6, immagine 1 di 2 How to Fix a Hole in a Pant Pocket: passo 6, immagine 2 di 2
    • Sew around the ending part a couple times to prevent it from loosen again.
  6. How to Fix a Hole in a Pant Pocket: passo 7, immagine 1 di 1
    • Tie a few knots on both ends of the closed tear to ensure the stitching doesn't come loose.
    • Carefully cut the remaining thread.
    • Be very careful while cutting the thread to avoid cutting some part of the material also.
Conclusione
Dolapo Ajose
Membro da: 09/20/21
244 Reputazione
1 Guida realizzata
1Commento della guida
I found a good reference video for this guide: https://youtube.com/watch?v=LJ5y4mLVbY0
5moufl - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 62
Tutti i Tempi: 5,333
