Introduzione
Gas stoves with uneven firing are a common household issue, often caused by blockages, misalignment, or wear and tear in key components. The problem typically arises from food debris or grease clogging the burner ports, improper placement of burner caps, or faulty ignition systems. These issues result in uneven heat distribution, making cooking inefficient and unsafe. Fortunately, it is easy to repair. You can clean the gas stove by removing residue manually and soaking it in water to further remove grease.
After the repair is completed, clean the stove regularly and keep the separators clean to prevent clogging again.
Cosa ti serve
Remove the burner cap from the stove.
Remove the burner head from the stove.
If the residue on the separator has not been removed, you can repeat the process. You can increase the concentration of the liquid, reduce the volume of hot water, or soak it for a longer time to achieve better decontamination results.
