Salta al contenuto principale
How to Fix a Dirty Sensor in a Corsair Harpoon RGB
Cosa ti serve
  1. How to Fix a Dirty Sensor in a Corsair Harpoon RGB, How to Fix a Dirty Sensor in a Corsair Harpoon RGB: passo 1, immagine 1 di 2 How to Fix a Dirty Sensor in a Corsair Harpoon RGB, How to Fix a Dirty Sensor in a Corsair Harpoon RGB: passo 1, immagine 2 di 2
    • Start by flipping the mouse over to view the flat side of the mouse.
    • Remove the mouse feet to reveal the screws holding the bottom and top part of the mouse together.
  2. How to Fix a Dirty Sensor in a Corsair Harpoon RGB: passo 2, immagine 1 di 3 How to Fix a Dirty Sensor in a Corsair Harpoon RGB: passo 2, immagine 2 di 3 How to Fix a Dirty Sensor in a Corsair Harpoon RGB: passo 2, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the screws that hold the mouse together.
    • Once the screws are removed, pull the mouse apart by holding the top and bottom pieces.
    • The mouse will be pulled into two pieces: the top (rounded part) and bottom (flat part).
  3. How to Fix a Dirty Sensor in a Corsair Harpoon RGB: passo 3, immagine 1 di 1
    • After the mouse has been pulled apart, the flex cable will be visible. This must be removed before continuing.
    • To remove the flex cable, gently pull the cable clip until it becomes unlatched.
  4. How to Fix a Dirty Sensor in a Corsair Harpoon RGB: passo 4, immagine 1 di 2 How to Fix a Dirty Sensor in a Corsair Harpoon RGB: passo 4, immagine 2 di 2
    • Remove the motherboard. The motherboard is mounted on the mouse, so gently remove by simply pulling the motherboard from within the mouse.
  5. How to Fix a Dirty Sensor in a Corsair Harpoon RGB: passo 5, immagine 1 di 2 How to Fix a Dirty Sensor in a Corsair Harpoon RGB: passo 5, immagine 2 di 2
    • Once the motherboard is removed, the optical sensor will be fully exposed. This is the piece that is causing the lag in the mouse.
    • The optical sensor is dirty, and needs to be gently cleaned with a Q-tip or soft cloth dipped in 90% isopropyl alcohol.
Conclusione
To disassemble, clean, and reassemble your mouse, follow these guidelines.
Altre 5 persone hanno completato questa guida.
3Commenti sulla guida
Muy buena guia. Me fue muy util. Gracias y saludos.
Bolzano - Replica Condividi
why did you opened it if you just cleaned eye with alcohol
antoncoinz - Replica Condividi
Excellent, needed to clean my scroll wheel sensor, this was helpful, thanks!
Nakkie Swanepoel - Replica Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 98
Tutti i Tempi: 9,412
