Salta al contenuto principale
How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard
Cosa ti serve
  1. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard, How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 1, immagine 1 di 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard, How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 1, immagine 2 di 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard, How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 1, immagine 3 di 3
    • Unplug the cord from the wall and the back of the keyboard.
  2. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 2, immagine 1 di 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 2, immagine 2 di 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 2, immagine 3 di 3
    • Flip over the keyboard.
    • Check the battery holder and remove the battery cover.
    • Remove all outer screws with a Philips screwdriver. These are the 19.0 mm Philips screws.
    • Remove the middle screw and the middle top screw. They are the 25.4 mm Philips screws.
  3. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 3, immagine 1 di 1
    • Carefully remove the cover, and set it aside.
    • Find the contact pad.
  4. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 4, immagine 1 di 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 4, immagine 2 di 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 4, immagine 3 di 3
    • At the top of the contact pad, carefully pinch the black clamps closed.
    • Once all the clamps are closed, wiggle the contact pad free.
    • Be careful of the small black hooks at the bottom.
  5. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 5, immagine 1 di 1
    • After the contact pad is free, gently lift it up.
  6. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 6, immagine 1 di 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 6, immagine 2 di 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 6, immagine 3 di 3
    • Vacuum and/or gently wipe the dust away.
  7. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 7, immagine 1 di 1
    • Place the contact pad back gently.
  8. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: passo 8, immagine 1 di 1
    • Place the cover back on.
    • Place the screws back in.
    • The 25.4mm Philips screws go in the middle and top middle. The 19mm screws go around the case.
Conclusione
Altre 2 persone hanno completato questa guida.
UW Tacoma, Team S1-G14, Cardinal Summer 2020 Membro di UW Tacoma, Team S1-G14, Cardinal Summer 2020
UWT-CARDINAL-SU20S1G14
1 Membro
1 Guida realizzata
Un commento
This is a good pictorial guide to how the keyboard works and how to service it, I used electronic switch cleaner {aerosol} on a cloth to clean the contacts and it was successful leaving all the keys working.
jeff may - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 42
Tutti i Tempi: 2,949
