Salta al contenuto principale
How to Fix a Corroded Outdoor Water Spigot
Cosa ti serve
  1. How to Fix a Corroded Outdoor Water Spigot, How to Fix a Corroded Outdoor Water Spigot: passo 1, immagine 1 di 1
    • Rinse the outside ring of the spigot off with water.
  2. How to Fix a Corroded Outdoor Water Spigot: passo 2, immagine 1 di 1
    • Once wet, apply 1 tbsp. of Bar Keepers Friend soft cleanser to the area(s) that has any built up residue.
  3. How to Fix a Corroded Outdoor Water Spigot: passo 3, immagine 1 di 1
    • Let the solution sit for 5-10 minutes.
  4. How to Fix a Corroded Outdoor Water Spigot: passo 4, immagine 1 di 1
    • Brush the cleanser that is on the spigot with a wire metal brush until you notice that the residue is gone.
  5. How to Fix a Corroded Outdoor Water Spigot: passo 5, immagine 1 di 1
    • Rinse the spigot off completely with water.
  6. How to Fix a Corroded Outdoor Water Spigot: passo 6, immagine 1 di 1
    • Using plumbers tape, wrap around the spigot once ensuring that is it fully covered.
  7. How to Fix a Corroded Outdoor Water Spigot: passo 7, immagine 1 di 1
    • Apply the connection for your garden hose securely to the spigot.
  8. How to Fix a Corroded Outdoor Water Spigot: passo 8, immagine 1 di 1
    • Turn on water to ensure there are no leaks/water sprays.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 15
Ultimi 7 Giorni: 76
Ultimi 30 Giorni: 400
Tutti i Tempi: 7,167
