Salta al contenuto principale
How to Fix a Carabiner
Cosa ti serve
  1. How to Fix a Carabiner, How to Fix a Carabiner: passo 1, immagine 1 di 1
    • Position the carabiner so that the gate is pushed forward past the nose and the latch is hanging out.
  2. How to Fix a Carabiner: passo 2, immagine 1 di 1
    • Position the pliers between the rivet pin.
    • The rivet pin is a flat rectangle metal piece poking out of the hinges.
  3. How to Fix a Carabiner: passo 3, immagine 1 di 1
    • Gently but firmly squeeze the rivet pin behind the hinge.
  4. How to Fix a Carabiner: passo 4, immagine 1 di 2 How to Fix a Carabiner: passo 4, immagine 2 di 2
    • Push the gate back, so that it is behind the nose.
    • Be sure to push the gate slowly and carefully, to avoid unnecessary jerking around, which could potentially break the carabiner further.
  5. How to Fix a Carabiner: passo 5, immagine 1 di 1
    • Position the gate back to the original position behind the nose.
  6. How to Fix a Carabiner: passo 6, immagine 1 di 1
    • The gate should now snap back into position securely. If it does not, repeat the process.
    • Be sure that the rivet pin was not bent or broken in the act of guiding the gate back to its original position.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
2 Commenti
Thank you for tutorial I was autism and bent it.
Vehicular manslaughter - Replica
Was gonna throw the old one away but this helped. Good as new now, thanks!
Maksim Krotov - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 19
Ultimi 7 Giorni: 118
Ultimi 30 Giorni: 568
Tutti i Tempi: 18,866
