How to Fix a Cabinet Door Hinge with a Damaged Base
Introduzione
If your cabinet door hinge is pulled off from the base use, this guide will show you how to fill the base and replace a new door hinge with extra support.
The door hinge is a mechanical bearing that attaches the door to its frame and works as a pivot point while opening and closing the door. Application of more weight and improper use can pull the door hinge and damage the base.
Before using this guide, inspect the door to take a note of how much the base is being ripped off. Can it be fixed with wood filler? If the base is pulled apart from the door, you may need to replace the door.
Note that the size of hinges and screws can vary according to the individual's need. So make sure to purchase the exact size accordingly. To find the exact size of the hinge check the hinge cup, use this photo or take the old hinge to the store.
Squeeze the wood filler in the damaged base of the cabinet.
Some wood fillers require you to mix them with hardener. For those types, add 1/3 amount of hardener with filler and mix them until a consistent texture. Then apply the mixture to the damaged area. For more clarity, watch this video.
Place a card beside the hole and fill the hole with wood filler.
Overfill the damaged base slightly, to ensure the hole is filled completely.
