Salta al contenuto principale
How to Fix a Button on an Umbrella
Cosa ti serve
  1. How to Fix a Button on an Umbrella, How to Fix a Button on an Umbrella: passo 1, immagine 1 di 1
    • Remove the 1.1 mm screw that fixates the handle to the umbrella using a Phillips #1 screwdriver.
  2. How to Fix a Button on an Umbrella: passo 2, immagine 1 di 2 How to Fix a Button on an Umbrella: passo 2, immagine 2 di 2
    • Remove the umbrella handle by pushing on the eject push-up button.
  3. How to Fix a Button on an Umbrella: passo 3, immagine 1 di 2 How to Fix a Button on an Umbrella: passo 3, immagine 2 di 2
    • Place a thin malleable metal in between the button’s connection to the metal projection.
  4. How to Fix a Button on an Umbrella: passo 4, immagine 1 di 2 How to Fix a Button on an Umbrella: passo 4, immagine 2 di 2
    • Apply permanent adhesive to secure the thin metal to the button's walls. Wait a few minutes for the adhesive to dry.
  5. How to Fix a Button on an Umbrella: passo 5, immagine 1 di 1
    • Verify that the button is firmly fixated to the metal ejector.
  6. How to Fix a Button on an Umbrella: passo 6, immagine 1 di 2 How to Fix a Button on an Umbrella: passo 6, immagine 2 di 2
    • Proceed to push down on the button while placing the handle.
    • The button goes through the handles button crevice.
  7. How to Fix a Button on an Umbrella: passo 7, immagine 1 di 1
    • Verify that the button is firmly fixated on the metal ejector.
  8. How to Fix a Button on an Umbrella: passo 8, immagine 1 di 1
    • Pound a nail with a hammer to prevent the opening system from turning.
  9. How to Fix a Button on an Umbrella: passo 9, immagine 1 di 1
    • Return the screw to fixate the handle to the umbrella.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 22
Ultimi 7 Giorni: 107
Ultimi 30 Giorni: 447
Tutti i Tempi: 16,515
