Salta al contenuto principale
How to Fix a Brother DCP-7060N Paper Jam
  1. How to Fix a Brother DCP-7060N Paper Jam, How to Fix a Brother DCP-7060N Paper Jam: passo 1, immagine 1 di 2 How to Fix a Brother DCP-7060N Paper Jam, How to Fix a Brother DCP-7060N Paper Jam: passo 1, immagine 2 di 2
    • Press the power button on the side of the printer to turn it off.
  2. How to Fix a Brother DCP-7060N Paper Jam: passo 2, immagine 1 di 1
    • Wait for ten minutes or until the printer has cooled down completely.
    • Touch the top cover to make sure the temperature has cooled down.
  3. How to Fix a Brother DCP-7060N Paper Jam: passo 3, immagine 1 di 2 How to Fix a Brother DCP-7060N Paper Jam: passo 3, immagine 2 di 2
    • Open the front tray carefully.
    • Check the status of the three rollers. If there is a paper jam, pull the paper out carefully.
  4. How to Fix a Brother DCP-7060N Paper Jam: passo 4, immagine 1 di 3 How to Fix a Brother DCP-7060N Paper Jam: passo 4, immagine 2 di 3 How to Fix a Brother DCP-7060N Paper Jam: passo 4, immagine 3 di 3
    • Pull two sides at the position in the photo to open the front cover.
    • Remove the drum from two sides in the position in the photo.
    • Draw out the toner at the photo position.
  5. How to Fix a Brother DCP-7060N Paper Jam: passo 5, immagine 1 di 1
    • Check inside if there is paper jam.
    • If there is a paper jam, carefully remove the paper with two hands and ensure there is nothing else inside.
  6. How to Fix a Brother DCP-7060N Paper Jam: passo 6, immagine 1 di 3 How to Fix a Brother DCP-7060N Paper Jam: passo 6, immagine 2 di 3 How to Fix a Brother DCP-7060N Paper Jam: passo 6, immagine 3 di 3
    • Turn the printer around.
    • Open the back cover of the printer at the position in photo.
    • Remove the back cover and check the status inside.
    • If there is a paper jam, take out the paper along the exit direction carefully.
  7. How to Fix a Brother DCP-7060N Paper Jam: passo 7, immagine 1 di 2 How to Fix a Brother DCP-7060N Paper Jam: passo 7, immagine 2 di 2
    • Close all covers and consumables bin.
Conclusione
Altre 3 persone hanno completato questa guida.
KehaoWu
Membro da: 01/15/22
224 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 92
Tutti i Tempi: 3,242
