Salta al contenuto principale
How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses
Cosa ti serve
  1. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses, How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 1, immagine 1 di 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses, How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 1, immagine 2 di 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses, How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 1, immagine 3 di 3
    • Apply dish soap to the broken temple arm sections.
    • Scrub the broken temple arm sections with the dish soap for one minute.
  2. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 2, immagine 1 di 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 2, immagine 2 di 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 2, immagine 3 di 3
    • Rinse the dish soap off of the temple arm sections with water.
    • Dry off the temple arm sections with a paper towel.
  3. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 3, immagine 1 di 2 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 3, immagine 2 di 2
  4. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 4, immagine 1 di 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 4, immagine 2 di 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 4, immagine 3 di 3
    • Use the coated toothpick to apply a thin layer of Gorilla Super Glue to one of the broken temple arm sections.
    • Gorilla Super Glue works better when less of the product is applied. Make sure to only apply a thin layer of glue to the broken temple arm section.
  5. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 5, immagine 1 di 2 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 5, immagine 2 di 2
    • Press the two temple arm sections together and hold for one minute.
    • Caution: Gorilla Super Glue can remain on your skin for up to a week. Place hands away from the glue applied when holding the temple sections together to keep hands clean.
  6. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 6, immagine 1 di 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 6, immagine 2 di 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 6, immagine 3 di 3
    • Tightly wrap masking tape around the area where you placed the temple arm sections together.
    • Leave the masking tape on for five minutes.
  7. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 7, immagine 1 di 2 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 7, immagine 2 di 2
    • Remove the masking tape.
  8. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 8, immagine 1 di 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 8, immagine 2 di 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 8, immagine 3 di 3
    • Select a 1/4" heat-shrinking tube.
    • Slide the tube to the area where you applied the Gorilla Super Glue.
  9. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 9, immagine 1 di 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 9, immagine 2 di 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 9, immagine 3 di 3
    • Plug in a handheld hair dryer.
    • Turn the handheld hair dryer to the highest heat setting.
  10. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 10, immagine 1 di 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 10, immagine 2 di 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: passo 10, immagine 3 di 3
    • Circulate the handheld hair dryer around the heat-shrinking tube until it is suctioned around the temple arm.
    • Caution: Keep your fingers away from the area you are aiming the hair dryer. The hair dryer produces high levels of heat that can irritate or burn a person's skin.
Linea Traguardo
Maia Michelle Brown
Membro da: 02/20/24
181 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 60
Tutti i Tempi: 817
