Salta al contenuto principale
How to Fix a Broken Pearl Necklace
Cosa ti serve
  1. How to Fix a Broken Pearl Necklace, How to Fix a Broken Pearl Necklace: passo 1, immagine 1 di 2 How to Fix a Broken Pearl Necklace, How to Fix a Broken Pearl Necklace: passo 1, immagine 2 di 2
    • Find the broken part of the necklace.
    • Remove all the pearls from the broken end of the thread.
    • Pull out the thread carefully so the pearls don't get lost.
  2. How to Fix a Broken Pearl Necklace: passo 2, immagine 1 di 1
    • Cut a piece of thread to the desired length with a pair of scissors.
  3. How to Fix a Broken Pearl Necklace: passo 3, immagine 1 di 1
    • Use the end of the thread to tie a knot around the clasp.
  4. How to Fix a Broken Pearl Necklace: passo 4, immagine 1 di 2 How to Fix a Broken Pearl Necklace: passo 4, immagine 2 di 2
    • Insert pearls in the thread until you reach your desired length.
    • Place each pearl individually until you're finished.
  5. How to Fix a Broken Pearl Necklace: passo 5, immagine 1 di 3 How to Fix a Broken Pearl Necklace: passo 5, immagine 2 di 3 How to Fix a Broken Pearl Necklace: passo 5, immagine 3 di 3
    • Attach the other clasp to the thread using a knot and cut the remaining thread.
  6. How to Fix a Broken Pearl Necklace: passo 6, immagine 1 di 2 How to Fix a Broken Pearl Necklace: passo 6, immagine 2 di 2
    • Close the necklace.
Linea Traguardo
Un commento
Eek. This is all wrong. Guess if you don’t mind sloppy pearls that WILL break sooner rather than later this will be ok. Otherwise if you want a classy and durable finished product this fix it technique will not give you that.
Lorelei Bee - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 79
Tutti i Tempi: 3,145
