Salta al contenuto principale
How to Fix a Broken Chef’s Knife Tip
Cosa ti serve
  1. How to Fix a Broken Chef’s Knife Tip, How to Fix a Broken Chef’s Knife Tip: passo 1, immagine 1 di 3 How to Fix a Broken Chef’s Knife Tip, How to Fix a Broken Chef’s Knife Tip: passo 1, immagine 2 di 3 How to Fix a Broken Chef’s Knife Tip, How to Fix a Broken Chef’s Knife Tip: passo 1, immagine 3 di 3
    • Submerge the whetstone in a container of water for 15 minutes or as directed by the manufacturer.
  2. How to Fix a Broken Chef’s Knife Tip: passo 2, immagine 1 di 3 How to Fix a Broken Chef’s Knife Tip: passo 2, immagine 2 di 3 How to Fix a Broken Chef’s Knife Tip: passo 2, immagine 3 di 3
    • Align your palm with the back of the blade (the blunt side), and wipe down the blade with a towel.
    • Avoid touching the sharp edge of the knife with your fingers at all times.
  3. How to Fix a Broken Chef’s Knife Tip: passo 3, immagine 1 di 2 How to Fix a Broken Chef’s Knife Tip: passo 3, immagine 2 di 2
    • Using a sharpie, draw a line from the back of the blade to below where the chip is.
  4. How to Fix a Broken Chef’s Knife Tip: passo 4, immagine 1 di 3 How to Fix a Broken Chef’s Knife Tip: passo 4, immagine 2 di 3 How to Fix a Broken Chef’s Knife Tip: passo 4, immagine 3 di 3
    • Remove the whetstone from the water container.
    • Place whetstone on a wet rag with the 400 grit side facing up.
    • Place the top side of the blade flat on the whetstone.
    • Begin to grind down the top edge of the blade with a back-and-forth motion until reaching the sharpie line.
  5. How to Fix a Broken Chef’s Knife Tip: passo 5, immagine 1 di 2 How to Fix a Broken Chef’s Knife Tip: passo 5, immagine 2 di 2
    • Rinse the blade in water and wipe off excess water periodically to remove metal shavings.
  6. How to Fix a Broken Chef’s Knife Tip: passo 6, immagine 1 di 3 How to Fix a Broken Chef’s Knife Tip: passo 6, immagine 2 di 3 How to Fix a Broken Chef’s Knife Tip: passo 6, immagine 3 di 3
    • Once you have shaved down the top of the blade, adjust the blade's position so only the tip is touching the whetstone.
    • Shave down the tip of the blade and adjust the position of the blade frequently to follow the curve of the sharpie line.
    • After reaching the sharpie line, flip the stone to the 1000 grit side and repeat steps 1 and 2 until the surface is smooth.
  7. How to Fix a Broken Chef’s Knife Tip: passo 7, immagine 1 di 3 How to Fix a Broken Chef’s Knife Tip: passo 7, immagine 2 di 3 How to Fix a Broken Chef’s Knife Tip: passo 7, immagine 3 di 3
    • Place the knife so the sharp edge is laying at a 15-20 degree angle on the whetstone.
    • Begin to grind the blade back-and-forth by pushing and pulling with your hands until reaching the desired sharpness.
    • Flip the blade over and repeat steps 1 and 2.
  8. How to Fix a Broken Chef’s Knife Tip: passo 8, immagine 1 di 2 How to Fix a Broken Chef’s Knife Tip: passo 8, immagine 2 di 2
    • Using dish soap and a sponge, clean the blade and rinse with water.
    • Using a dish towel, wipe away the excess water and dry the blade.
Linea Traguardo
Allen Ma
Membro da: 11/05/24
157 Reputazione
1 Guida realizzata
UC Davis, Team 4-4, Vidal-Chiesa Fall 2024 Membro di UC Davis, Team 4-4, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S4G4
3 Membri
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 301
