Salta al contenuto principale
How to Fix a BIC Wite-Out Mini
Cosa ti serve
  1. How to Fix a BIC Wite-Out Mini, How to Fix a BIC Wite-Out Mini: passo 1, immagine 1 di 1
    • Place the dispenser component with the logo facing down, with other components laid out on a clean, flat surface.
    Chiedi a FixBot
  2. How to Fix a BIC Wite-Out Mini: passo 2, immagine 1 di 1
    • Stabilize the small gear with tweezers to prevent further unwinding.
    Chiedi a FixBot
  3. How to Fix a BIC Wite-Out Mini: passo 3, immagine 1 di 3 How to Fix a BIC Wite-Out Mini: passo 3, immagine 2 di 3 How to Fix a BIC Wite-Out Mini: passo 3, immagine 3 di 3
    • Untangle the plastic strip by rotating the large gear in a circular motion, going in the opposite direction of the spiral.
    • Stop once the plastic strip connecting the gears is straight.
    Chiedi a FixBot
  4. How to Fix a BIC Wite-Out Mini: passo 4, immagine 1 di 3 How to Fix a BIC Wite-Out Mini: passo 4, immagine 2 di 3 How to Fix a BIC Wite-Out Mini: passo 4, immagine 3 di 3
    • Feed the plastic strip into the small gear until the white-out strip is visible.
    • Turn the big gear toward the small gear until they are close to each other.
    Chiedi a FixBot
  5. How to Fix a BIC Wite-Out Mini: passo 5, immagine 1 di 1
    • Place gears back into dispenser component with the logo.
    • Place the small gear onto the module closer to the dispensing slot.
    • Place the large gear onto module farthest from the dispensing slot.
    Chiedi a FixBot
  6. How to Fix a BIC Wite-Out Mini: passo 6, immagine 1 di 1
    • Hold the white-out strip with tweezers and pull to wrap the strip around the dispensing slot.
    • Make sure to stabilize the gears.
    Chiedi a FixBot
  7. How to Fix a BIC Wite-Out Mini: passo 7, immagine 1 di 3 How to Fix a BIC Wite-Out Mini: passo 7, immagine 2 di 3 How to Fix a BIC Wite-Out Mini: passo 7, immagine 3 di 3
    • Wrap the black band around both gears.
    • If necessary, stabilize the large gear with tweezers.
    • Wrap the band starting from large gear to small gear.
    Chiedi a FixBot
  8. How to Fix a BIC Wite-Out Mini: passo 8, immagine 1 di 2 How to Fix a BIC Wite-Out Mini: passo 8, immagine 2 di 2
    • Close the device until the side components click closed.
    Chiedi a FixBot
Conclusione
Congrats! You have just successfully repaired your BIC Wite-Out Mini!
Test your BIC Wite-Out Mini to make sure that it works correctly. If it does not work, repeat steps 1-8 and try again!
Lauren Miller
Membro da: 01/31/24
157 Reputazione
Una guida realizzata
UC Davis, Team 3-1, Andersen Winter 2024 Membro di UC Davis, Team 3-1, Andersen Winter 2024
UCD-ANDERSEN-W24S3G1
3 Membri
1 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 7
Ultimi 7 giorni: 44
Ultimi 30 giorni: 221
Tutti i Tempi: 2,883
