Introduzione
Growing up, I have always played on an Xbox, and I have had problems with drift stick several times with different controllers. This problem becomes annoying over time when playing first and third-person video games. When I play video games, I want to perform the best I can, and I couldn't with a drift stick. Since those experiences, I decided to create this guide to help others running into the same problem. You'll know when a controller has a drift stick when your character moves or looks all over when not touching the controller. Fixing the issue doesn't take long, and you only need two items one 70% Isopropyl Rubbing Alcohol and 3 to 4 cotton balls. If the analog stick on the controller is already falling apart and is messed up, just get a new one.
Strumenti
Ricambi
Nessuna parte specificata.
Remove the batteries from the controller.
After fixing the controller, if there are any more problems, later on, repeat the same process to have it working again.
